Question about Jandy Laars Lite2 Lj 250,000 Btu Heater
Jandy LJ Pool Heater
My LJ heater is set to 104 and but only heats up to 96 & shuts off .
  • Mark Hively
    Mark Hively Mar 24, 2014
    I have replaced the heat sensor and the Heater Control Assembly
    Top Expert:
  • Jandy Master
  • 8,143 Answers
Temp sensor might be going bad but you can go into menu and calibrate up to 4 degrees each way
Posted on Jun 07, 2015
5 Suggested Answers
SOURCE: Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
  • 22 Answers
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
Posted on Feb 18, 2009
guru_fixya
  • 944 Answers
SOURCE: 6My heater heats my pool
The sensor is the defective one.Just pull the sensor from the pipe by loosening the stainless steel clamp that holds it in the pipe.Then follow the wire back into the Aqua link box and unplug. Get a new one at your local store and replace. It's a common problem and you should be able to do it with ease.The water temp is attached to a pipe, and held on by a hose clamp, and the air sensor should be located near the box, and looks exactly the same as the water sensor (minus the hose clamp).
When it is set to higher temperature it is not able detect the heat.For safety purpose the Jandy heater will turn on and off.
It turns off due to false temp deducted and also turns on due to same reason.
The sensor will look like this replace it
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 30, 2010
guru_fixya
  • 944 Answers
SOURCE: No dispal on Jandy LXR
If Heater continues then the problem is with the LCD display. LCD display has to be replaced.The LCD display has flex type connection leading to it.You just remove it and place it properly.If still you cant see the Display just replace it.It will cost very less.
Thank you for using fixya have a nice day:-)
Posted on Sep 22, 2010
Heating is limited
The system has one temp but the heater temp should be turned all the way up outside on the unit as well
Jan 03, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Heats to only 72 degrees
make sure heater is set to 104 degrees aqua link controls temp
Heats to 72 degrees
try setting heater all the way to 104 the aqualink should control the heat
My apollo spa galaxy II D20Nj will not heat past 85 can you tell me what I should do or part to get to fix this serial #BSJLJEG
make sure spa setting is at 104 degrees if at 104 degrees see control system if ok change temp sensor either in heater or control unit
Dec 07, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy Lite2 LJ Heater Power Control Board
there should be a blue card on the board for 220 vs 120 if has zip tie set for 220 if no zip tie 120 volt read card also
Jul 11, 2013 | Jandy R0366800 Lite2 LJ Heater Power...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Heater reads spa water 15 degrees higher than it is
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Feb 22, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Pool heater leakage
Rob Cox
POOLCENTER.com
Jan 23, 2009 | Jandy Digital Lite2 Lj325 Btu Heater,...
Jandy Laars Lite2 Lj 250,000 Btu Heater Logo
145 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
