Question about Brother CS6000i Computerized Sewing Machine
The needle bar of my brothers cs6000i is bent. The repair shop is asking $120 labour and $20 for the part. Is there any way I can fix it myself
Needle bent and out of palace
    Champion:
    Habit-Forming:
  • 201 Answers
Hai, You can try to take one screw driver [ or asking cycle repair shop, elctrician ] put the bent side adjust the needle bar.
Posted on Mar 28, 2014
SOURCE: brother ult disney machine
Marty, it happened to me! I figured it out, if you need help, feel free to email me, it is the bobbin carriage was not put it--not the bobbin spool, but the whole carriage. feel free to email me and I can walk you through it! I just saved myself a trip to the repair! :)
pyles_brandi@yahoo.com
Posted on Jan 03, 2008
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
Australian S
  • 46 Answers
SOURCE: Brother CS6000i - Needle breaking, bobbin thread not picking up
There are a few possible causes, firstly make sure you have the correct needle and it is in the correct way and make sure when you fit the needle it is pusshed all the way up into the needle holder. If the shuttle or hook is moving around the bobbin case then the timing may have been knocked out. If the it is not moving it means either the gear or belt that drives the hoo / shuttle has been damaged or broken.
Posted on Jul 02, 2009
  • 255 Answers
SOURCE: The timing?? is off.
Unfortunately, with modern machines about the only way to reset the timing is to take it to a repair shop.
Sorry about that.
Posted on Jan 12, 2010
SOURCE: Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Posted on Aug 02, 2012
Bar that hold the sewing foot is loose
If the comment already posted did not answer your question, here is another thing to check. If the screw that attaches the foot and ankle to the presser foot bar is tight, and the foot can still be moved, it is likely that the presser foot bar has become loose within the lifting mechanism. You could save yourself some trouble by taking your machine to a sewing machine repair shop, but if you would rather avoid that expense, do the following. Remove the needle bar and take up mechanism cover on the left side of the machine. This is held on by a single phillips head screw on the back side of the machine, which, with the back of the machine facing you, should be on the top right side of the machine. Once this cover is removed you will be able to see two vertical metal shafts, one is attached to your needle clamp and needle, and should be in the front. The other is the presser foot bar, and will be behind the needle bar. There should be a small allen screw about halfway up that shaft that tightens onto the bar. With the presser foot properly positioned on the needle plate, tighten this allen screw. Don't tighten the screw too tightly, as this can damage the presser bar, just make sure it's nice and snug. Make sure the presser foot raises and lowers properly, and re-attach the needle bar cover.
Hope this helps.
Mar 16, 2014 | Brother CS6000i Computerized Sewing...
Needle bar frozen
Rather suspect the bar has bent, remove it and check for true
Dec 18, 2013 | Brother SE400 Computerized Sewing Machine
Brothe cs6000 needle bar noise
if the plastic compartment opens try using a couple of drops
of sewing machine oil on the needle bar and see if that helps.
Feb 08, 2013 | Brother CS6000i Computerized Sewing...
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
When sewing, the thread keeps pulling the fabric threads and the result looks messy. I've tried playing with the thread tension but it won't help.
have you tried using a new needle- if the needle is the slightest bet bent or or damaged it can cause problem with the fabric threads
if the needle is not the correct one for the fabric, it can move or damage the fabric threads
also clean under the needle plate for loose threads or lint also in the bobbin area
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
My needle keeps hittng my presser foot
My first guess is that your needle is bent. Replace the needle and see if that helps!
Jul 08, 2010 | Brother CS6000i Computerized Sewing...
Needle will not stay in? i install needle, tighten thumb screw and the needle falls out??why??
Buy a new pack of needles to make sure you do not have defective needles, if that doesnt work get a new thumb screw and if it still doesnt work you need a new needle bar.
May 25, 2010 | Brother XL-5130 Mechanical Sewing Machine
Brother CS6000i... the needle threader broke. A spring fell out and now it's loose and doesn't work. How do I get into it to fix it?
Contact your Brother dealer and ask if this is something you can fix.
If this mechanism is inside the machine, you may do more harm and that could result in more expense and invalidate your warranty.
Mar 25, 2010 | Brother CS6000i Computerized Sewing...
The needle hits the throat plate
if a new needle still wont align with the needle plate, your needle bar is out of whack
Mar 18, 2009 | Brother CS6000i Computerized Sewing...
Brother CS6000i Computerized Sewing Machine Logo
100 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
