Question about Fish
Jin long aquarium pump
Is it possible to get parts (hose connectors) for jinlong external filter? I've tried everywhere but no luck.
4 Suggested Answers
  • 105 Answers
SOURCE: I HAVE TO DRAIN 3 YEAR OLD FUEL FROM 1989 GRAND PRIX SE
If you take the off it might drain a little bit but your best bet is to take the hose off turn the key on and let the pump drain the tank. There is also another thing you can do use an air compressor and blow air into the fill tube on the fuel tank just be sure you dont use to much this will blow the fuel out the fuel line after you take it off the filter.
Posted on Mar 18, 2009
  • 3600 Answers
SOURCE: Heater hose connector broken off in intake
If you had a welder you could slide the bolt into the hole tack weld it on and that tap lightly with a hammer and turn it out with the bolt. You want the bolt to be 3 or 4 inches long and just slide in one weld on each side and you should get it to come out.
Posted on Jul 05, 2009
  • 41 Answers
SOURCE: Whirlpool Duet Sport Washer (model: wfw8300sw02)
puzzled here because there is always some water left in machine this is normal .you are quite right when you say that when you take the drain hose out of stand pipe and lower it water comes out but that is because of gravity .
Posted on Jun 07, 2011
I'm having trouble with my tetra filter
You can solve this with a simple hose clamp from any hardware store. Take the hose with you and they will get you the right size one.
Aug 05, 2014 | Tetra Whisper Ex70 Aquarium Power Filter
Assistance help..4 hours of failure
If the unit is used, sometimes crud will cease the unit. you could clean it out real good and see if that helps.
I am not familiar with the unit, but another thought would be to see if there is a mechanism for "self priming" and make sure no hoses are kinked etc...
I hope you have better luck.
Apr 26, 2014 | API Filstar xP-XL extra large Canister...
What is an external aquarium pump?
External aquarium pumps are very powerful pumps that pull water out of the aquarium as well as return filter water back to the aquarium. In addition, external pumps are used in order to run protein skimmers and different types of filters such as canister filters.
Sep 06, 2012 | Fish
I have a new 306 fluval cannister filter-the flow is not strong at all-just wondered, is it supposed to be a strong flow or gentle return back into tank?
A 306 should be quite strong, first check the flow regulator is fully open, check that the filter motor is the right way round on the filter bucket, check hoses, inlets and outlets for obstructions, try running without media in the filter bucket. Best to try this stuff in the bath!!!
Aug 15, 2012 | Hagen Fluval 306 External Filter For...
Are there aquarium filters that I do not have to put into the tank itself? Maybe something that can work from the outside?
Yes. There are both internal and external filters. External filters are normally hung outside the aquarium or placed under it inside the aquarium stand. Some of these filtration systems include power filters and canister filters.
Aug 14, 2012 | Fish
What kind of filter should I buy for my aquarium?
In my opinion, power filters are the best. They are easy to maintain and are also quite economical. The most common style of power filter hangs on the back of your tank. A siphon will pull water from the tank, eliminating any bacteria and returning filtered water back into the aquarium.
Aug 14, 2012 | Fish
How do I change the water pump in my aquarium?
There are a few simple steps to follow in order to changeyour aquarium's water pump:
  1. 1. Turn off all electrical componentsof your tank including lights, filters, vacuums etc.
  2. 2. Remove all of the fish andplace them in ample fresh water
  3. 3. Remove all of thecomponents of the pump (some internal and some external, depending on yourmodel)
  4. 4. Familiarize yourself withthe different parts of the water pump. Obviously, the exact installation process will vary from product toproduct
  5. 5. Lay out and attach all newtubing
  6. 6. Build the small pieces ofthe pump and insert them in place
  7. 7. Install the filters andsump (if relevant)
  8. 8. Plug in and turn on allelectrical components. Ensure thateverything is functioning before returning the fish to the aquarium
  9. 9. Return the fish to the aquarium
May 13, 2012 | Fish
I'm trying to fix an old aquarium light that I found. Do you know where I could buy used parts to repair it?
EBay is always a great source for used goods. I've provided a link of a general search Iperformed regarding used aquarium lighting parts. If it doesn't help, I suggest contacting yourlocal pet supplier.http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=used+aquarium+lights&_sacat=See-All-Categories
May 13, 2012 | Fish
What is the difference between a filter and a pump in a fish tank?
A filter maintains a natural environment that for fish thatbalances the good and bad bacteria in the tank. Additionally, a filter can remove toxins, chemicals and other unwantedmaterials from the water. The filterworks by taking water in from the tank and returning it clean.A pump is just a pump. It pumps air into the tank and creates bubbles, and sometimes a current. It does not clean the tank or balance thebacteria and PH like a filter does.
May 13, 2012 | Fish
I , i try to find the fuel filter for my hyundai elantra 2001
The fuel filter is located under the rear seat in a compartment above the fuel tank. Also, a filter sock at the base of the fuel pump located
in the fuel tank.
On 2001 models the fuel filter is part of the fuel pump. To replace the fuel filter, disconnect the negative battery cable, remove the back seat and take fuel pump cover off to get to the fuel pump.Then you have to 1) disconnect the electrical connector from fuel pump/fuel sending unit, 2) disconnect the high pressure hose and the fuel return hose from the fuel pump and 3) remove the fuel pump mounting flange screws. You can then lift the fuel pump and replace the filter.
Good luck and hope this helps
Apr 19, 2009 | 2001 Hyundai Elantra
Fish Logo
141 people viewed this question
Top Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Fish Expert? Answer questions, earn points and help others
