Question about Neff B1421 Electric Single Oven
F5 error and no heat but fan is working... is f5 related to element not working
Fan oven not heating up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
No heat from oven although fan and light are both working
hello gavin..... Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
This is an inexpensive part and relatively easy to replace. Call your local appliance store to obtain the part and the instructions on how to install it. Joe
Thanks for choosing Fixya!
Jan 05, 2011 | Belling XOU270 / XOU271 Electric Single...
Heating elements will not heat and getting an error code E1 F-5
Hello,the lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed screw driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Thanks
May 30, 2010 | Whirlpool Ovens
Fan does not switch off (had problem for about a week), now the heating element has blown. Could the two things be related? It is a Belling Format 646HBL oven.
Yes both things are related. It is likely the temperature sensor has failed 'on' allowing the fan to run continuously and the heating element to overheat.
You will need to replace both.
Jan 11, 2010 | Ovens
The fan oven is not heating up. The fan appears to to be operating and the element for the grill heats up . I had the oven element replaced over a year ago.
If the fan is working o/k, but there is no heat, then it is more than likely the element that has failed again.
The fact that you had it replaced a year ago, does not mean tha it will last a long tiime, it is quite common for them to fail in a relatively short space of time.
Take my advice and fit a new element.
Thankyou.
Dec 03, 2009 | Baumatic Ovens
Bottom Element Open Circuit & Fan Element not working
No resistance in a bake element is a bad element. Replace it.
Most fan come on with a rise in heat. No heat/no fan.
Apr 08, 2009 | DeLonghi Ovens
Have a Kenmore Elite oven. When I try to turn on any of the heating elements, I receive an F5 error. Any suggestions? Thanks much.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 | Ovens
Neff B1421 Electric Single Oven Logo
18 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
