Question about RIM BlackBerry Pearl 8130 Cellular Phone
The keypad and trackball arent working and it keeps taking random pictures and going to the voice command and wont stop
  • 541 Answers
Change the settings
in menu select applications --> select options --> select keyboard/screen --> change resolution sensitivity (vertical and horizontal) to 100% --> select menu --> select save
Posted on Jun 16, 2009
    Scholar:
  • 50 Answers
Did it get wet at all? If so there is an area under the track ball that goes bad if it get's wet. Cleaning that area with a brush can sometime get it up and running again. If you're out of warranty try to remove the trackball and clean the area below it if necessary. There is a Blackberry Repair Guide that shows how to open a Blackberry and remove the track ball yourself. There are also third party blackberry repair services that will do this for you.
Posted on Jun 17, 2009
My blackberry won't let me type A, sometimes when i slide the trackball up it shows symbols. The trackball won't go up or down in texts and blackberry messenger. It just stopped working randomly and I used...
I a suggesting cleaning your trackball, the steps and information along with pictures will be provided below. I followed these same steps and mine works fine. Trackballs can easily accumilate dirt and dust over any period of time.
First, you'll have to use the screwdriver to remove the ring from the outside of the trackball. I'd recommend doing this from the top, since it's the only part of the wheel that doesn't have a prong (you'll see what I mean when you pull it out). Once that is loose, you'll be able to take the trackball unit out as well. The set should look like this:
Now we want to concern ourselves with the trackball unit. First, wet your finger and run it across the trackball to pick up any residue which might be sticking to it. Next, you'll notice there are four black wheels on each corner of the unit. Remove them one by one, removing any dust or buildup with your fingertips. I'd recommend not using water here. Just something about water and BlackBerry that makes me uneasy.
Finally, we'll look back to the unit, where you'll see a copper sensor where the trackball used to be. Wipe this gently with the rag. This is a very fragile and very sensitive part. If you treat it roughly, it will break and you'll have a worse problem than a dirty and clogged trackball.
Finally, drop the trackball unit back into the crevice, and pop the ring back on, prongs facing left, right, and down. Voila! Should be good as new. And now you don't have to send your BlackBerry to IT, or out for repair. Now if this does not work, you can order a replacement trackball from ebay for less than 3 dollars and just use the examples above to install it.
Mar 06, 2011 | RIM BlackBerry Pearl 8100
My tracker ball won't scroll down
go on ebay and put in the seach your phone model and trackball. they arent expensive and it fixes your problem. that happened to my trackball and i replaced it and now it works great
Jan 03, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry trackball wont work
I have the Blackberry Tour.......I work in all kinds of environments....so I get dust, dirt, and debris in my trackball......every 3-4 weeks I cannot move the trackball.......all you gotta do is get AIR DUSTER, the same you use for your computer keyboard etc. and keep it about 3-4 inches away and spray the air at your trackball and move it around......just keep spraying it for about 1-2 seconds at a time and move the ball around after every spray and you are good to go!!!!!
Nov 09, 2009 | Lands Phones
My blackberry trackball and keypad stopped working. I can scroll with my trackball but not click and my keypad does not respond. How do I fix this?
the trackball need to be clean or replaced as for the keypad it may need to be service but it might be a software issue and the OS may need to be reflash so it would be best to take the phone to a mobile shop and have it diagnose.
Oct 14, 2009 | AT&T Blackberry Curve 8300 Smartphone
All the buttons stopped working...
This is because Keypad is not functioning,the solution is to go to your nearest service centre and repair your Keypad.The Service centre contact number and address will be provided by your service provider.
Jul 13, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Voice command turn off?
Voice command is activated by the side button that is alone (right side if your facing the phone's screen) when the phone is closed. I don't know how to prevent the phone from doing that, but I do know how to make sure the phone does not say "Please say a command."
Menu
Settings and Tools (Far right icon)
Tools (#2 on the list)
Voice Commands (#1 on the list)
Hit settings, which is going to be the right bumper button (above the CLR key)
Go to prompts (#5 on the list)
Mode (#1 on the list)
It will be currently set on prompts, which is why it says "Please say a command." You can either set it to readout or tones only. Tones produces a short beep. Readouts only displays text (no noises). Being that you have your phone on silent, I assume you want readouts.
That will at least prevent stop the phone from making random statements in your pocket. Hope this helps.
Apr 19, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
Voice command keeps starting up
Hi i have the same prob how di i uninstall it
Nov 12, 2008 | Nokia e65 Cellular Phone
RIM BlackBerry Pearl 8130 Cellular Phone Logo
273 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
