Question about GE Pro Series Corded Speakerphone with Digital Answering System 30385EE1
Phone jumps from line to line on own
Beeps and jumps from line to line on its own
I need to rerecord the greeting message for my phone system.
According to the instruction manual, which can be found at: http://telephones.att.com/docMgt/public/art/175/1872_manual.pdf,
TO RECORD AN ANNOUNCEMENT:
1. Press A.
2. Choose the announcement location by
pressing s until the appropriate
mailbox is displayed.
3. Press R. Begin speaking after the beep
4. When you are finished, press S.
You will hear your new announcement.
5. Repeat Steps 1-4 to record another
announcement
— OR —
Press S.
TO REVIEW YOUR ANNOUNCEMENT:
1. Press A.
2. Press s to choose the announcement
you want to review (A, B, C, AO,
MBOX 3, MBOX 4).
3. Press P to hear the selected
announcement.
Or, if you're away from the office,
CHANGING ANNOUNCEMENTS:
You can re-record any of the announcements
currently in use by any
line or mailbox.
1. Contact the answering system.
2. After two beeps press a number key
(1-4) to select a line or mailbox, then
press 4*. The system beeps and begins
recording.
3. Speak into the telephone in a normal tone
of voice.
4. Press # when you are finished. The
system beeps once and plays the new
announcement.
To review your announcement, press a
number key (1-4) to select a line or mailbox.
Press 41 after the two beeps to play
your announcement.
NOTE: If announcement is being used by
both lines, re-recording the announcement
will change the announcement heard on
both lines.
Hope this helps!
tkhusa420
Sep 25, 2009 | Lucent 1872 Corded Phone
5 beeps after jump start on 2002 corolla
THAT IS THE ANTI THEFT SYSTEM,ITS OK AS LONG AS U CAN STAND THE BEEBS
Jul 13, 2009 | 2000 Toyota Corolla
Computer beeps but doesn't start.
The beeps are an error code. Most times they are signifying a RAM or video card problem. With your explanation I would check the video card first. The card might have overheated or just plain crapped out on you. Try replacing and rebooting. Hopefully this will have fixed your problem. Sorry. Hope this points you in the right direction & Good luck.
Jun 03, 2009 | Intel AOpen XC Cube EZ65 P4 Media PC...
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
My phone wont jump to the next line
that is up to your telephone service provider. call them and info them off the problem. tell them that you want a busy forward only to line 2. that way after 4 rings it will jump to line 2.
Feb 19, 2009 | Panasonic KX-T7730 Corded Phone
Can't make outgoing calls
You have to press a Line to call out. Line 1 or Line 2 or Line 3
May 13, 2008 | NorStar M7310 Corded Phone
Internal page
Hopefully this is already fixed, if not log in for a chat and I can help.
Apr 18, 2008 | Samsung Prostar 816 Phone
BT Freestyle 2200 do dial tone
I have this model of handset but as a triple. I get three beeps from the handsets if the batteries are low or flat.
Are your phones getting charged?
However,
Try putting the base station into a different phone line/ socket if you have one.
if not - Try putting a corded phone on your phone line. Maybe there is something faulty with the socket, maybe there is no dial tone due to faulty wires?
Mar 07, 2008 | British Telecom Freestyle 2200 Trio...
Canon Pixma830 all-in-one beeps when I connect it to my phone line
When you attach the phone lines, the line coming from the wall must be put in the "L" (line) jack on the machine. The extension phone can be plugged into the other jack. If you have the line coming from the wall to your phone first, and then the extension line coming to the machine, you will get the beeping. You must have two lines plugged into the machine.
Jan 11, 2008 | Canon PIXMA MP830 All-In-One InkJet...
RCA 4 line phone
Hi Richman,
If you have more than one phone line which I assume that you do -if one party has not completely hung up the handset after putting someone on hold when you pick it up on your end you will hear that beeping noise that you are talking about. Have them pick back up the line while you are on it and replace the handset again on thier phone to disconnect completely.
I hope this helps (trial and error)
Thanks
Oct 04, 2007 | GE 29488GE2 Corded Phone
GE Pro Series Corded Speakerphone with Digital Answering System 30385EE1 Logo
21 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
