Showing error code 3802 - Office Equipment & Supplies
SOURCE: Error 3802
printer can not talk to printhead... power off. wait. power on
Posted on Sep 17, 2008
SOURCE: ERROR CODE 3802
This is how I fixed this problem may or may not work for you. I removed the ink!!! Then I removed the ink tray. This is fairly easy if you fell the top of the ink tray you will find a small square that is slightly raised push in on the square while pushing down on the tray this will release the print head. Very carefully clean with 92% alcohol and a q-tip! Don't apply pressure to the print head it will ruin it!!!!!!!
This allow to air dry for at least a 5min. Reinsert then recalibrate the printer! go to printer status and at the very top you will see a rench and hammer icon press it then follow directions!!!!!!
Good luck and god bless
Posted on Dec 25, 2008
SOURCE: kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
Posted on Apr 19, 2009
bob_computer
  • 3153 Answers
SOURCE: error 3802 how do i fix it?
You should take it back and exchange it or read on below.
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the internet or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well
Posted on Sep 11, 2009
MUKHTAR
  • 2017 Answers
SOURCE: Printer shows error code 3802
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  5. Close the printer access door.
If the error continues:
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error continues, contact Kodak.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 16, 2010
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
My printer is showing error code 3802, I do I do?
Hello Dave,
The error that you are showing means Error: "Printhead is missing, not installed correctly, or has come loose" (105-3513) Please use the following link to help you trouble-shoot and fix this error:
Error Printhead is missing not installed correctly or has come loose 105...
Feb 26, 2015 | Kodak ESP5250 All-In-One InkJet Printer
Printer error shows error code 3802 and won't print
  1. Upgrade your printer firmware to the latest version
  2. If your printer firmware is already up-to-date:
  3. If the error continues:
  4. If the error continues,
for more help visit https://cbrtechsolutions.net or
CBR Tech Solutions
Feb 16, 2014 | Kodak Esp 5250 All-in-one Inkjet Printer
Error code 3802
CBR Tech Solutions
Jan 19, 2014 | Kodak Office Equipment & Supplies
Printer will not clear the Error 3802 , what do I do?
Hello and Welcome to FixYa!
Error 3802 generally occurs in the Kodak Inkjet Printers.
To solve this error Turn the printer off and then turn on, this problem is solved by doing this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If you are still facing this then do it again almost five times & if still your problem is not solved and you still get error code 3802 then probably your KODAK EASY SHARE 5500 All-In-One Ink Jet Printer is in need of servicing by a service professional.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you and Keep using FixYa!
Aug 17, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Error code 3802
You give scant information for your comment - you don't really ask a question - so I am flying in the dark so to say.
Here is what I did find and I hope you fine it applicable and useful. http://www.fixya.com/support/t4349159-printer_shows_error_code_3802
As I said you dont give much info - like make and model of printer ...
Mar 19, 2010 | Office Equipment & Supplies
What is error code 3802
"Printhead Failure" (error code 3802)
  3. Remove and install the printhead two times.
  4. Wait 30 seconds to allow the printer to reset.
  5. Connect the power adapter to the printer. Turn the printer on if necessary.
  6. Close the printer access door.
If error condition continues, contact Kodak for printhead replacement.
Best of Luck
Nov 17, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
ERROR CODE 3802
Nov 03, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error 3802
Sep 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
16 people viewed this question
jasbo
jasbo
