Question about LG WM0742HWA Front Load Washer
LG Front Load Washer WM0742HWA leaking from bottom toward right rear of machine -small load large load no difference- Have cleaned the front pump filter & tube, no blockage in drain hose, happens
Anybody out there know about this issue?
5 Suggested Answers
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 15 Answers
SOURCE: LG WM2487 Leak Front Left
Not sure if this machine is similar to the WM2277, but here is the procedure for that - my leak was in the "baffels" hose that connects the drum to the drain pump:
1. Drain the machine - pry the panel at the front left lower corner to get access to a stoppered tube. drain as much water from here as possible.
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right (there is a wire connecting the door to the machine on the right)
Posted on Apr 27, 2009
  • 105 Answers
SOURCE: LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
Posted on Aug 02, 2009
  • 66 Answers
SOURCE: I have an LG WM2277HW front load washer that is
check ur inlet hoses on the outside of machine, also check the connections inside the panel in back
Posted on May 08, 2010
I have a LG front load washing machine, about 6 years old which leaks at the front bottom left side. I had General Appliance Inc. fix it. They said it was the pump system. $ 470 later I still have...
its not the pump, if it was you would have lots of water usually, a small leak could be a hose or hose clamp that needs adjusting check that first
Oct 19, 2011 | LG WM-2277HW Front Load Washer
What does a pump filter consist of on a front loader tromm
Get some towels ready for the floor'
Open the small door on the left side bottom
Unscrew the large black cap pull out and clean filter
Jul 02, 2010 | LG WM-2277HW Front Load Washer
Were is the drain system manualy
To access thr pump and filter, remove lower rear cover of washer.
The pump and filter are located at the bottom rear right of washer.
To clean filter, remove large black hose onto drum, and clean filter inside hose.
Hope this helps.
Jan 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
LG front loader WD 8050FH
Be sure to remove the pin catcher assembly, at the bottom front right of the machine. Usually a small door at lower right side. Tip machine back and unscrew the large handle and remove to clean.
Jan 02, 2010 | LG WM2487H Front Load Washer
LG Front load washer
I JUST FOUND THE LEAK ON MINE JULY 5. THE DISCHARGE HOSE ON THE BOTTOM SLOWLY ROTTED THROUGH. THIS GOES FROM THE TUB TO THE DISCHARGE PUMP. ABOUT $9-10 ONLINE- BE SURE TO FIND AND DOWNLOAD THE PDF SERVICE MANUAL. TELLS YOU HOW TO TAKE THE MACHINE APART THE RIGHT WAY.
Jul 04, 2008 | LG WM-2277HW Front Load Washer
Just trying to gain access inside the calypso
Take a small flat head screw driver or putty knife. Put a thin peice of cloth over it so as to not mar the finnish on your machine. Using a flash light look between where the top panel and the front panel meet. There will be two flat green peices of metal. Using your putty knife or screw driver, push on these clips towards the rear of the machine while lifting up on the top portion. Once you get the two clips off, you'll be in. There will be 4 screws across the top of the front panel. Remove these and you'll be able to pull the top panel upwards and remove it. Next, pull the washer forwards and lean the top console back towards the wall until it can rest against the wall without trying to fall back forwards. Across the bottom towards the front, there are 3 5/16" screws. Remove these and the bottom panel will come off. The pump is on the botom right hand side with the two large back hoses attached. I prefer to put a large, shallow container underneath to catch anyremianing water when I dis-connect the hose(s) to try and remove debris from the pump.
Jun 26, 2008 | Kenmore 15864/15862 Top Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
LG WM0742HWA Front Load Washer Logo
63 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
