Question about Air Purifiers
String line broke
Anyone know what the 2 lines are for that run vertical in base unit and visible when you remove filter and made of in a brookstone ion filter 1 of mine is gone and Brookstone is of no help.
  • 3,899 Answers
What is the model number as it could be anything, there are a few models made and some have more that other do, ion senor bars and diffusers etc it could be any of these.
Posted on Apr 03, 2014
2 Suggested Answers
SOURCE: how remove and clean filters from Brookstone pure ...
how to remove and clean filters for the Pureion UV air purifier?
Posted on Jun 14, 2010
I have a hunter air purifier model number 36316 and need to know how to change the filter
Hello, this is Ava with Think Crucial.
To change the wick filters of your humidifier:
1. Turn off the unit and unplug it from the wall outlet
2. Remove the tank for the housing.
3. Locate the 3 lock tabs in the base of the unit. Turn them clockwise until the base of the tab lines up with the indentions in the base and lift off the housing.
4. Locate and turn the lock tab clockwise on the base holding the wick fram. Remove the wick frame and set it aside.
5. Remove the old wick by pulling the bottom of the wick out of the frame first and discard.
6. Insert the new wick top first. Ensure wick is in between the tabs at the top of the wick frame then slide the bottom part of the wick into the fram, making sure not to crush the bottom corners of the wick.
7. Reassemble the unit and refill the water tank if necessary.
8. Turn the unit back on and resume operation.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?page=1&q=hunter&type=product
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Dec 16, 2013 | Holmes Products HAP422-UC Air Purifier
Help!
Try leaving it unplugged for a while to reset it.
Jul 23, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Brookstone Pure Ion Pro clicking noise, ineffective. I understand the "sparking" is ok, but my unit doesnt "spark". The fans run, and the unit makes two different clicking noises; ...
did you ever figure out the clicking noise problem?
mine stared doing the same darn thing after I whashed the filters and inserted them into the units, I used the builted in drying setting, and thats when the problem started. I know you are not supposed to run the unit with a wet filter, thats why I put it on the dry mode first. I think I am just going to return them back to Brookstone.
Jul 08, 2012 | Air Purifiers
The string inside my ionic breeeze quadra is broken. Is it possible to fix it
Not so fast with the screwing part. Go to a music store, buy the G string wire(008)gauge- at least 41 inches long- for a guitar.
If you have a digital camera make a video/pics history of your dis-assembly steps.
Remove the ozone eliminator-by pulling it off the tower.
Start with the base 4 screws, followed by the 2 collar screws at the base.
NOTICE that there is a space between the two halves at the bottom. I paid NO attention to this space-boy did I ever try to snugly close that one before I looked at another one to see that this separation is there for a reason.
Next: remove the "TINY"12 screws - 6 on the front/back side of the units ribs-look for these.
Take pics of each step. You will be happy you did this.
Store all of these diff. screws in separate jars.
Open the unit now like a wallet. Notice that the sloped top control button/light module can now be removed. See those 2 black square plastic covers-they hide a spring and an upside down W shaped wire holder. The broken wire can now be removed. If you are lucky, you may be able to to twist your new wire-after pushing it through the cleaning bead -with the one going down to the bottom module. Mine was too brittle and broke apart as soon as I touched it.
Remember: The 2 wires you see are just one 41 inch long 008 gauge guitar string.
They thread through a signal contact bracket at the bottom of the unit that is activated by the breaking of the wire to turn the unit OFF. Getting to this bracket is somewhat difficult and requires patience. Take a lot of pics to be able to reassemble the S 1637. I pulled the 41 inch long string under this signal bracket, evened off the ends, moved the top module down 2 inches and twisted the ends around the W shaped bracket that compresses the spring.
Honestly, I had to adjust the spring two times because I left off the cleaning bead. Now just reverse the steps and you got your unit working. The new string seems to push a lot more air.
Before you replace all of the screws, fold the unit together, insert the blades , put 2 sets of veggy rubber bands around the top and bottom and plug in/turn it on. Mine works now better than new. Did I mention that I had to do 2. The second was done in 2 hours.
Good luck.
totrosko@yahoo.com
Mar 28, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
How remove and clean filters from Brookstone pure ion uv air purifier?
May 21, 2010 | Brookstone Pure-Ion UV Air Purifier
Unit shuts off after about 4 hours of running
You can get a manual on line. Go to www.brookstone.com , select "customer service", then select "product manual archives". It will come in a printable pdf file.
Dec 02, 2008 | Brookstone Pure-Ion (506840) Air Purifier
I need to buy one filter
we are also expierencing the same crackling problem. This machine is only a year old.....
anyone find anyway to resolve the crackling? I have not contacted Brookstone, but it doesn't sound too promising anyway.
These air purifiers are not cheap and they should back up their products.
May 17, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Unit seems stuck in the "drying grid" mode
I had the same problem with my GP. It has worked great for four years and only recently seemed to get stuck in this drying cycle. I cleaned the grid many times, cleaned the wires, cleaned the whole unit as much as I could to no avail. The trick: You need to clean the two metal prongs and surrounding area that insert into the bottom of the grid, when you inserrt the grid. they are sharp like nails, so take care. Use an alcohol based cleaners and clean the prong and around each base. This fixed the problem for me and she's back up and running well.
Aug 31, 2007 | Sharper Image Hybrid GP (SI724) Air...
Air Purifiers Logo
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
