Question about Siemens RWB29
Siemens RBW29 programmer when the programmer is off the boiler firers up and stays on for about 1minuate then goes off, the indication panel shows the letter C in the window. in the boiler manual it
The boiler firers up and stays on for about 1minuate the goes off, the indication panel shows the letter C in the window. in the boiler manual it says that this means the central heating or hot water is on. this is happening even when the programmer is in the off position.
3 Suggested Answers
danekeeper12
  • 6 Answers
SOURCE: SIEMENS SE64630GB NOT TAKING IN WATER
  • hot water valve selinoid and cold water selinoid valve are magnetily operated valves located in the lower part of the dishwasher that need electricity-----
  • wire loose?
  • kinked supply hoses and
  • my favorite is the valve at the kitchen sink angle stop is lying to you, indicates open but is really still shut (broken valve stem) or it has corroded shut .
Posted on Aug 15, 2008
SOURCE: siemens rwb29 controller doesn't work properly. central heating comes up only when you select hot water, but not on its own
This happens to my rwb29 from time to time. You can try switching off the power to the controller for a couple of minutes with CH thermostat and CH programs set off. Or you can press the little reset button to the bottom right of the LCD screen. After 1 or 2 attempts these steps usually restore the independent control on my unit.
Posted on Nov 25, 2012
My heating will not switch off. The 'heating on'
I have the same problem . Did you fix it ? P Hayes
Mar 31, 2010 | AT&T Siemens S46 GSM Cellular Phone
I'm a plumber and was looking at a friend's Ariston Microgenus 28 kW combi boiler today. The problem is the DHW comes out tepid, then within a few seconds of the burner igniting, the temp indicator lights...
Many boilers seem to use a more or less common type of thermister although actual fixings vary. My experience of one of these from another brand of boiler was 670 ohms at 10 deg C and 10 -11 k ohms at 20 deg C
Dec 10, 2009 | Combi Centre DX - Mango
Alpha boiler - wireless programmer failing
it sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Jan 05, 2009 | Water Heaters
Glow worm combi boiler
check the pilot line for an obstruction. check the millivolt generator that's supposed to keep the pilot valve open. check for a high limit control being bad.
Dec 14, 2007 | Desa International GWP20T GLOWARM Wall...
Siemens RWB29 Logo
190 people viewed this question
Top Siemens Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Siemens Heating and Cooling Expert? Answer questions, earn points and help others
