Question about Electrical Supplies
Arrow ebn 320 stopped working after driving a few brads
I was installing paneling with 5/8 brads when after firing about 12 brads it stopped working .The light comes on when I pull the trigger but gun will not fire.
jj505
  • 195 Answers
SOURCE: paslode fixing gun has stopped firing
Do you have gas cylinder in,if so is gas expiration date on bottom of cannister,change gas to current fresh date. Also open nose of nailer and see if a fastner has logged ,remove and push plunger pin back into body,be sure to remove battery during these tests.
Posted on Mar 19, 2009
  • 24 Answers
SOURCE: Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Posted on Apr 14, 2009
  • 1383 Answers
SOURCE: brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Posted on Apr 27, 2009
  • 142 Answers
SOURCE: Gun's drive rod not retracting back after firing a nail
you need a top end rebuild kit
Posted on Jan 05, 2010
  • 14 Answers
SOURCE: gun does not fire every time
When you cleaned it, you may have pinched the large brown o-ring that is around the fan. Take gun apart again and reassemble. before you place the orange head valve cover on, press the nose of the gun into a wood surface and assure the o-ring goes into chamber unrestricted. Basically, the aluminum fingers of the cylinder should not pinch off the o-ring.
Posted on Jan 10, 2010
Testimonial: "I ordered a rebuild kit and this took care of the problem!(spark plug, new filter o ring etc) Thanks for all the assistance!!!"
Nail gun has stopped firing nails
make sure that the nails are loaded in straight and packed down tight
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
The sensor Honeywell TC807A 1036 (Smoke Detector), is compatible with a NFS-320 Fire Alarm Control Panel?
I don't know if that particular smoke is compatible or not, but the NFS-320 is a commercial rated UL864 Revision 9 fire panel, which means the documentation is part of the UL listing. This means that in order for a device to be compatible with the system, it must be listed in the Installation Instructions as compatible. I couldn't find any mention of that particular smoke in any of the documentation I found for that alarm panel.
Oct 23, 2012 | Honeywell Tc807a1036 Smoke Fire Detector...
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
My Brad sudddenly stopped working. Makes a Psft
If you've not already tried applying air motor oil to the gun than you should do this first. If this does not solve your problem than it's very possible that your main diaphram is worn or poruse. Thank you, Dana
Mar 31, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Brad nailer not firing properly
need to rebuild. the kits are about $15
Jan 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Cant find replacement brads for swingline
the problem was not with a stapler it was with an electric brad nail gun made by swingline , after researching this, my swingline (printed right on the gun) turned into a "powerfast electric nailgun model 32003" which will take arrow replacement 1" brads .
May 04, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Feb 21, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Electrical Supplies Logo
18 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
