Question about Tomtom RIDER 2nd Edition GPS
Tomtom rider 2nd edition just taken off old motorcycle and put on to new motorcycle won't work,but will work when plugged into main 240v charger,any ideas?
    Sergeant:
    Champion:
  • Tomtom Expert
  • 373 Answers
Blown voltage regulator that controls the battery
http://compu-sat.co.uk/repairs%20voltage%20overload.html
Posted on Mar 25, 2014
homemender
  • 158 Answers
SOURCE: TOMTOM RIDER V2
Internally , the Rider is very similar to other tomtom models . From what you describe it sounds like your charger has gone faulty ( quite common ) . There is a sensing wire that goes from the charger to the plug tip to check the voltage is at 5v . If this sense wire becomes detached or broken then the charger will increase the voltage and unfortunalely , in turn fries 2 chips inside your TomTom . ( these are numbers U24 and U25 in most tomtoms ) . Its not possible for a standard electronics technician to repair these as it need someone experienced with these tiny components and also requires use of special tools and soldering techniques. You will have to have it repaired by either TomTom or a suitable TomTom repair centre . Even then , if the blown chips have got really hot then it's possible they have burnt the circuit board tracks and in this case a repair isn't possible. Throw the existing charger away as if you do get it repaired plugging that one in could easily cause your TomTom to blow again. You can check the voltage output of your charger using a multimeter which would probably confirm what I say above . Sorry to be barer of bad news.... Good Luck
Posted on Nov 13, 2008
  • 3 Answers
SOURCE: tomtom rider will only switch on whilst under mains power and on
If it will switch on when connected to mains or car charger then perhaps your battery has had it. My battery no longer retains charge even when not in use. Suggest try new battery.
Posted on Feb 12, 2009
  • 4090 Answers
SOURCE: over loaded via 12volt mains adaptor
at great expense cheaper to buy a new one
Posted on Aug 01, 2009
  • 4090 Answers
SOURCE: my tomtom wont charge through car charger or pc
It is possible that the cvar charger fuse has blown. Undo the tip and remove and replace !amp fuse and all should be fixed.
Please rate my help++++Thanks for using FIXYA
Posted on Dec 08, 2009
  • 23 Answers
SOURCE: I have a TomTom Rider 2nd Edition. I need to
You can purhcase the new TomTom Rider 2 map update for $79 from TomTom.
If you have your receipt as proof of purhcase, you maybe able to take it back to the retail store you purhcased it from and see if they can assit you with TomTom.
Contact TomTom customer support directly to see if they can assist you also.
Good luck
Posted on Apr 03, 2010
TomTom Rider unit wont charge. Tried mains charger, USB connector and bike charger. Swapped out the battery and the unit boots up but that is just the charge in the new battery. Any help appreciated.
Power board is faulty, repair or replace. Workshop repair required. Oh, stop plugging a charger into the USB socket. It doesn'tlike it, thats for data transfer only. The round pin socket is the charger port
Oct 30, 2013 | Tomtom RIDER GPS Devices
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
My tomtom rider 2 will not turn on
My tomtom rider 2 will not charge on my bike and will not charge from mains electric, when i use my tomtom in the car it works.
Cheers Tim
Mar 23, 2011 | Tomtom RIDER GPS Devices
I have a TomTom Rider 2nd Edition. I need to restore the SD card how can I get this done.
Good luck
Apr 03, 2010 | Tomtom RIDER GPS Devices
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
Over loaded via 12volt mains adaptor
Jul 31, 2009 | Tomtom RIDER GPS Devices
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Need tomtom rider 2 2nd addition docking shoe
Forget TomTom. Go buy this one
http://www.wunderlichamerica.com/mm5/merchant.mvc?Screen=PROD&Store_Code=WA&Product_Code=8600880&Category_Code=
I talked to TomTom multiple times on the phone and had same problem but finally found this. It's better quality and it's available.
Mar 24, 2009 | Tomtom RIDER 2nd Edition GPS
Tomtom rider will only switch on whilst under mains power and on
Feb 10, 2009 | Tomtom RIDER GPS Devices
TOMTOM RIDER V2
Oct 05, 2008 | Tomtom GO 910 GPS Receiver
Tomtom RIDER 2nd Edition GPS Logo
79 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
