Question about Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan
Bathroom exhaust vent cover
Remove cover
What is the size or model for a replacement vent cover in bathroom w/ fan?
open up cover remove screen then remove crank assembly go on roof and slide it off to the side bring it to your dealer because there are different kinds of hinges
Oct 26, 2015 | Holiday Rambler 2012 Traveler 32RLS
Can I connect two bathroom fan ducts to a single roof vent?
No, both cannot be connected to same vent.
Or vent exhause from 1 fan will vent into other bathroom.
All house vents require separate duct.
Nov 26, 2014 | Broan-NuTone Fan,Bathroom Exhaust Broan...
How do I remove the cover to replace the light bulbs on a Round Nautilus brand bathroom exhaust fan from the 1980's.
Most exhaust fan covers use a spring steel wire in a V shaped configuration. The bottom of the V is attached to the cover. There is a slot in the fan housing and by pinching the tops of the V togetherand insert them in the slots the spring pressure pulls the cover up tight to the ceiling.Carefully pulling the cover down enough to reach over the cover and pinch thewires together should allow the cover to be removed. Hope this helps.
. Bob
Aug 09, 2014 | Broan nutone Broan/nautilus Bathroom...
Nutone bath fan how do you clean the vent
Usually the vent cover pulls straight down, and is held in place with 2 V-shaped metal spring wires.
Squeeze each spring wire together to release cover from ceiling box.
Use vacuum to clean vent fan housing. Some vent fans can be disassembled and motor housing removed for cleaning. Do NOT use water on electric motor. Simple vacuum, or dry toothbrush cleaning is good enough.
Spay tiny bit of WD40 on the fan motor shaft or add tiny dab of white grease if desired.
The plastic cover can be scrubbed with soap and water, rinse to remove soap residue, and when dry, paint with aerosol spray paint using 3-5 very light coats applied in 5 minute intervals.
Jul 28, 2012 | Broan-NuTone Fan,Bathroom Exhaust Broan...
The bathroom exhaust fan in our bungalow is leaking this past week every few days , we are not handy folks and so we are wondering what type of professional do we call in to deal with this leak and...
Sounds like the issue is simply condensation inside the exhaust pipe where it passes through the un-heated attic space. If you use the shower and the exhaust fan, lots of humid air is passing over the inside surface of a very cold duct, then running back down to your bathroom ceiling. You could get any non-specialist handyman to wrap insulation around that duct in the attic. But you can mitigate the problem by running the fan for a few minutes before you start the shower (thereby pre-heating the duct before you give it a blast of moist air) , and leaving it run for 20 minutes afterwards (thereby drying out the duct after use). Regarding the discolored ceiling, the handyman can apply some stain-covering white primer too.
Jan 14, 2011 | Fantech Fans Exhaust Fan In-Line
New bathroom venting in basement bathroom.
Install a window mounted exhaust fan if you can discharge to the outside of the house surrounding atmosphere.But undercut the door of the batroom to allow air coming in into the room.Alternatively firt a door grill 600 x 150 mm size which is more expensive.THe size of the fan should be 50 to 100 l/s of air flow.
Mar 24, 2008 | Fantech Fans Exhaust Fan In-Line
Moisture on bathroom exhause vent
the fan is pulling too many cfm (cubic feet per minute).you can replace the switch of the fan with a potentiometer type switch (this works like a light dimmer)you can reduce the speed of the fan,or you can use a couple of synthetic fiber filters to trap the condensation.good luck
Jan 04, 2008 | Fantech Fans Exhaust Fan In-Line
Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan Logo
23 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
