LG smart 3D tv vertical line with a blinking screen
The tv has a large vertical line running through the left side and its blinking
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Sounds like a T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 24, 2014
  • 138 Answers
SOURCE: Thin vertical line running down the right side of the screen
See if you can use the remote to shift the picture to the right. It depend on how far the line is to the right. If that don't fix the problem the set will need to have internal boards replaced. It may be the logic board and the logic buffers...
Posted on Oct 06, 2008
  • 8 Answers
SOURCE: red line on screen
you need a new video board on your tv i can sell you many boars you may know need i am also a full service man for tvs and electronics
573-433-1925
Posted on Jan 05, 2009
MNfisherman
  • 11896 Answers
SOURCE: LG 42
One of your system boards is failing. Possibly the "Y" convergeance board. The LCD Capacitors will most likely have to be replaced.
Posted on May 05, 2009
techman007
  • 1112 Answers
SOURCE: LG DT42PY10X Plasma left hand side is blank,
Hi:
You are going to have to replace the display driver Boards for the X Substain board. The two board are called hand insert buffer display drivers.
You can go to http://www.partstore.com
The part #'s are as follows:
LG Electronics/Zenith 6871QDH068B Y DRIVE TOP This is an alternative to LG Electronics/Zenith part 6871QDH068A LG Electronics/Zenith 6871QLH037A XRLT ASST X-LEFT
LG Electronics/Zenith 6871QDH069A Y DRIVE BOTTOM
Posted on Dec 24, 2009
SOURCE: Vertical colored lines on left half of screen.
I had this problem on a 37" Viewsonic LCD. Pulled it apart and through a process of elimination, I traced the problem back to a small board with several flat white ribbon cables coming out of it. The board was near the top center of the screen and under a ton of other equipment requiring almost a total disassembly.
This small board was clean but I noticed one of the rubber standoffs had slipped down and was making contact with one of the outputs running to the LCD. It also happened to be the output running to the section of the screen with the problem.
I postulated that the sticky glue on the rubber standoff may have just enough conductivity to cause a problem. Moved it so that it was no longer touching anything electrical and then reassembled the TV.
Afterwards, I turned it on and was pleased to see the problem has gone away! If you're having the vertical line problem, then maybe this could be your problem too, especially if you have a Viewsonic since it could be a manufacturing defect.
Posted on Mar 22, 2010
Samsung plasma tv has vertical lines
The most cost effective thing to do is just replace the TV. The cost to repair will be close to the cost of a new LED flat screen, they are very cheap now.
Aug 21, 2016 | Samsung PN51F8500 51" Full HD 3D Smart...
How do I get the red line off the left side of center of the screen? It runs vertical !!!
HI
if the line is temporary then re connect the cables in side the tv but the line is permeant then change the panel because this kind of line is in side the panel & not removed.
thanks
Jan 17, 2016 | Sony BRAVIA KDL-60R550A 60" 3D 1080p...
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
White line on my LG 55lw5600
Just visit the site linked here. It has screen-shots to defective plasmas & LCDs. You can compare it to that of your TVs' and make sure about the fault, to an extent. It will be best I assume.
Nov 29, 2013 | LG 55LW6500 55 3D HDTVReady LCD TV
Not sure what happened with my LG 47" 3D tv. There
Did u hit the screen or touch ( applied pressure ) while it was on?
Aug 18, 2013 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
