Question about Kenmore Dishwashers
Dishwasher overheating replaced the thermostat but still overheating
Overheated. Why won't it start?
I'm not really familiar with JEEP mechanics but if you've replaced your water pump and it's still overheating with full water/coolant level, you should check the thermostat; when it fails, it's a common cause or overheating in all kind of cars
I'm attaching some links to Youtube tutorial about replacing thermostat in a Jeep but you can expand your Google search using terms
Youtube replace thermostat JEEP Liverty
https://www.youtube.com/watch?v=Y3NpLdG993U
Jeep 4 0L straight six thermostat replacement
Thermostat Replacement Overheating fix Part 1 Jeep
How To Change the Thermostat in Jeep Wrangler
2002 Jeep Grand Cherokee Thermostat Replacement
Replacing the radiator thermostat in any Jeep Cherokee Jeep liberty Jeep...
Sep 10, 2015 | Jeep Liberty Cars & Trucks
Thermostat tripping
I just fixed my Maytag's bi-metal switch. I smacked it with the plastic end of a screwdriver. Problem solved. You may have venting issues in the dishwasher if it's continually overheating.
Jan 30, 2014 | Maytag Dishwasher
Smeg dishwasher overheating
No feedback from thermostat sensor or faulty switch.
Oct 15, 2013 | Smeg Dishwashers
Replacing a thermostat on a dishwasher
you are most likely referring to item 16 in this diagram. You can order the part and replace it. This is the limiting thermostat which protects the unit from overheating.
However the heater thermostat is item 41 in this diagram. this controls the heater temperature.
Oct 30, 2011 | Maytag MDB7100AWB Dishwasher
Why does the interior of my dishwasher look so dried out? And why are my NEW and old plastic dishes getting hard and white? I just traded dishwashers out and my other one didn't have this problem. Can...
Are the plastic dishes you mention dishwasher safe. they should have a symbol on them to say they are? What you describe is a typical sigh of overheating, but it may be possible that the new machine thermostat may be faulty and is running too hot. If you feel this is the case and the machine is new, it is safer to consult the dealer rather than risk losing your warranty because the machine was tampered with.
Feb 18, 2011 | Whirlpool Dishwashers
My fdw60 dishwasher stops when it reaches drying the drying light and the salt refill light keeps flashing what could this be
I have the same problem. This means the dishwasher is overheating. Sometimes the plates are too hot to touch and we are loosing the glaze from our crockery. There does not seem to be a thermostat spare part and therefore I changed the heating element but this has not solved the problem.
Nov 12, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hobart Commercial Dishwasher - LX40H is overheating the water when it fills up. I have checked the programing and all set points are correct. When we open the door to load the dishwasher, It steams...
Well problem seems in the  Timer -
Although it's uncommon, the timer or the selector switch may be defective. If so, then it cause the dishwasher to overheat, you need to replace the Timer, because it can't be repaired.
Good Luck!!
Thanks
Sep 05, 2009 | Dishwashers
Wash water heats up to over 200 degrees even when off!
There is a bad thermostat. If you want to further pursue, let me know.
Apr 23, 2009 | Dishwashers
My Hobart LXI dishwasher is overheating to the point where the water begins to boil.
is it the wash or rinse? in either case there are two temperature probes in the tanks check to see if they are dirty if not then you may have control board problems. if you are not familiar with this type of equipment then you should probrably call a service company.
Aug 20, 2008 | Dishwashers
Dishwashers Logo
22 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
