Question about Brother DCP 130C All-In-One InkJet Printer
Printer paper jam
Paper jam, have removed paper but it tore so small particle left in system? won't print makes screeching noise
  • Anne Simpson
    Anne Simpson Mar 24, 2014
    Well I removed the colour cartridges and tipped the machine upside down and shook it gently, as recommended by somebody and I was up and running but only for a shortwhile. I had another paper jam, removed all the jammed paper this time but the machine won't print again, strange noise and this time Im sure there's no paper stuck as I made sure it was all removed. Anyway, thanks for your help. I will have another go in the morning (patience is a virtue) and try adjusting the paper tray maybe as suggested it is holding the paper too tight.
  • Brother Master
  • 783 Answers
Go To Below official Brother Printer Page For Your problem, How do clear paper jams Brother Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Posted on Mar 24, 2014
Soulvisitor
  • 1113 Answers
SOURCE: printer screen tells me that there is a paper jam - no paper left in printer
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Posted on Dec 25, 2007
the kowalski
  • 86 Answers
SOURCE: message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Posted on Jun 02, 2009
komguy
  • 2306 Answers
SOURCE: clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Posted on Jun 24, 2009
SOURCE: Brother MFC-5840CN Unable to clean
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
Posted on Jul 19, 2009
  • 13 Answers
SOURCE: Repeated paper jams from the brother hl2070n after remove toner
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Posted on Apr 15, 2010
Ricoh Aficio SP213w jams
Hey Check the catridge it properly seated or not in no then remove and reinsert.
If yes then replace with new one.
Apr 20, 2016 | Ricoh Aficio Office Equipment & Supplies
Carriage jam error
A paper jam
If you've had a paper jam, normally after you clear it, a small amount of paper sometimes gets left behind and gets shunted onto the sidewall of the printer by the carriage, which stops the carriage reaching its full travel and throwing up an error, rendering the printer unable to print or carry out any other function. Simply remove the paper and switch printer off and on and it will reset.
If you have an error of any other kind, many remedies and fixes for these can be found on my website http://www.the-inkstore.co.uk/frame/pages/epson.htm
Regards
Aeronautical
Oct 25, 2012 | HP OfficeJet 6110 All-In-One InkJet...
I had a paper Jam and know printer error 5100 mesage is coming up, I turned off the printer for 5 min but when I turn it back on it make a turn nois and then a screeching noise then stop.
Sometimes when you get a paper-jam and remove the sheet, there can be little pieces of paper still stuck in the machine. This will cause your printer to do exactly what you are describing. Also remember that when removing a paper jam, use caution and care when removing the paper. To much force can damage the rollers and small gears inside your machine.
I hope this assists you,
Regards,
Nico
Jul 06, 2011 | Canon MX882 All-In-One InkJet Printer
The paper had jammed when i was printing, i removed the jammed paper and tried printing again. however, the display on the printer shows paper jammed. what now?
You may have left behind a tiny piece of paper that tore off your sheet as you removed it. Make sure that you have all of the jammed paper and look carefully for any remnants inside. Look to see if the printer did not pick up a second sheet that is still in the system somewhere.
Jan 25, 2011 | Canon PIXMA MX310 All-In-One Printer
How do i reset a lexmark c534n? It won't let me print because it says there is a paper jam, but there isn't any paper in the machine
There might still be paper in the machine.
Or perhaps a small torn off chip of paper caught on a sensor somewhere.
If you recently had a paper jam, make sure you cleared it properly, and did not leave any bit behind, especially if thpaper tore as you removed it.
Check all doors and remove the toner cartridge to look underneath it.
Good Luck
Dec 07, 2009 | Lexmark C534N Printer
Paper jam
Remove back part of the printer. View the printer roller usually in the heater area, if there is still small particles or paper left.
Mar 02, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printer says it has a paper jam even after it has been cleared
The screeching sound is caused when the print head reaches the end of its travel and hits the paper jam which you cannot see using the suggested jam-clearing steps. So
1. unplug the printer
2. lift the cover so the blue support on the left holds the cover up
3. plug in the printer, watch the printer head move
4. after it stops, gently move the printer head toward the middle and look at the far ends of travel. you should find the cause(s) of the jam up against the sides of the printer. remove with needle-nose pliers.
5. replace cover, plug in the machine. it will go through a cleaning or 2, but it should be ready to go after that
Nov 23, 2008 | Brother Multi-Function Center MFC-240C...
HP laserJet 6L printer making noise/not printing correctly
The problem with the screeching sound and horizontal lines printing is no lubricant for a small motor, not the main motor. To fix this problem, download the service manual which shows how to remove the case. You’ll need a phillips screwdriver and some machine oil or something similar to Z-Max. When the printer is apart and you’re facing it, on top there’s a compartment with a metal cover plate (shield) held by two screws. To the left is a spring loaded switching system that rocks into position when it’s called, and presses on the tab of a leaf switch. With the printer plugged up, you can press on the leaf switch which will engage the printers system, causing the printer to attempt printing. During this you’ll hear the screeching sound you’re describing. This is your test procedure during this repair. Next, notice the two multi-wire connectors at each end of the compartment. One bundle runs across the top of the compartment and connects on the other side. Remove both connectors and the two screws that hold down the shield; one holds down a metal pressure tab, also to be removed. This releases the shield exposing a small circuit board that has a control IC and a small motor. Three screws holds this circuit board to the printers plastic casing. Taking care not to handle the circuit traces (IC Static Protection Protocols), remove the screws and remove of the board. On this board is a small motor with it’s flywheel held down by a square weight and a pressure tab. Remove the top tab and the weight, turn the plastic guide to the side, and lift the flywheel away from the motor. Apply the lubricant to the shaft of the flywheel and reassemble the system. Try your switch test. Chances are, it’ll work without all that screeching. If you get that far, trust me, it’ll print. The "finge"
Sep 27, 2008 | Office Equipment & Supplies
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
How to clear internal paper jam on CLX-3160FN Samsung Multifunction Printer
Get rid of it. Your problems will only get worse. Mine is going to the landfill.
May 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Brother DCP 130C All-In-One InkJet Printer Logo
127 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
