Question about Ontel Products Pro Chopper Plus with Tri Blade Technology
Crank not working to cut
When trying to chop top crank goes only one way and will not choop
Salmonella on raw chicken, do not wash?
http://www.cdc.gov/salmonella/general/prevention.html
also use separate chopping boards
https://www.foodsafety.gov/keep/basics/separate/
Cut up chicken does not go with Salad / un cooked foods on same chopping board and hands with cut up chicken does not go with with Salad / un cooked foods
Eggs are another source - had a bad food poisoning incident in Melbourne Australia caused by eggs in Mayonnaise.
http://www.dailymail.co.uk/health/article-2055844/Never-meat-shelf-beware-raw-vegetables-Could-fridge-KILL-YOU.html
Meat never goes on top shelf !
Oct 29, 2016 | Crock Pots & Slow Cookers
How to check the electric brake on a dewalt 706 type 1 chop saw
The power cord can get a break in it. Try moving it when this happens. Otherwise, the plug can fall out of the outlet. Sometimes the switch goes bad.
Jan 25, 2015 | Dewalt Saws
Renault scenic card
Hold the card so the chopped corner is away (on the right) from you and the gold pins are underneath, that the way the card goes in or depending on model, cut corner to the top and gold pins facing right if its the sideways slot
Jan 13, 2014 | Tomtom GPS
The stone on my chop saw stops cutting. Why?
Sometimes the edgeof a cutting disk can become clogged with particles of the material being cut e.g. cast iron or soft metals.
Try cutting a piece of brick or other hard material to chip away the edge of the disk to expose new abrasive
Mar 30, 2010 | Dewalt Chop Saw D28700
How to us cusinart 11 cup food proceessor for chopping. cutting.
You can download the user manual for the DFP-11 from
http://www.cuisinart.com/parts/food_processors/dfp-11.html
Click on the "download user manual" hypertext link on the right under the processor picture. You need to have Adobe Reader loaded to be able to read the manual.
Please rate this solution. Thanks.
Oct 22, 2009 | Cuisinart DFP-11 Deluxe Food Processor
Outside corner one side 30 down [ crown moulding ]
If the corner is to be 90 degrees than all you need do is set the compound angle on your chop saw at 15 degrees to get the 30 degree down side. If you cut only one side the thickness will be different at the joint so you have to spit the angle. Boy now you got me going. Tomorrow I'm going to be trying this cut in the shop myself. Good luck.
Apr 05, 2009 | Saws
Need Manual / Info For Old Delta Chop Saw / Cold Saw
The machine should have a data plate somewhere. This may give blade RPM or motor rpm, then its out witrh the calculator to work out the blade speed. The crucial number however is not the rpm but the peripheral speed in feet or meters per minute.
Used to work with a power tool manufacturer, a standard woodcutting chop saw will safely cut alloy. Two things, watch the blade type, and watch out for metal swarf entering the motor and switchgear !.
Feb 26, 2009 | Delta Saws
Daewoo Zoom
Try the aspect ratio. Some aspect ratios have an auto-zoom function where it automatically goes in about 50%, cutting out around 1/4 of the edges (or, if you're watching 4:3, maybe even up to 1/3...although I'm not sure of that).
Mar 02, 2018 | Televison & Video
Ontel Products Pro Chopper Plus with Tri Blade Technology Logo
457 people viewed this question
Top Ontel Products Home Experts
john h
Tom Chichester
Are you an Ontel Products Home Expert? Answer questions, earn points and help others
