Question about Blitzz Technology BWA711 Router (b000220deo)
Can not laptop to connect
I juat purchased a new laptop and I can not get it to coonect to my Blitzz Bwa711 router. It recognizes the signal but says it is unable to connect. when i diagnose the problem it says it did not receive a response from router. HELP!
    Scholar:
  • 92 Answers
Wireless Troubleshooting Checklist 1. Unplug power from Router and Modem for 3 mins. 2. Restart computer. 3. Make sure your wireless device is active: a. Verify that your wireless device is turned on. Some laptops have a physical hardware switch located on the case. Make sure this is in the ‘On’ position. Other laptops use a Function Key combination (e.g. Dell uses Fn+F2, IBM uses Fn+F5)
b. Open Network Connections (from the System Tray or from the Control Panel). Verify that your wireless Connection is Enabled. If not, right-click on your wireless connection and select ‘Enable.’
4. Renew your connection. Changes elsewhere on the network can sometimes knock out your connection. To reconnect quickly, click Start, Run in XP (or press the Windows key in Vista), type ipconfig /renew, and press Enter. 5. Check for interference. Have you installed any new wireless devices (speakers, baby monitors, ect)? If so unplug them. Make sure your wireless network has a unique name (ssid). 5. If other wireless devices can connect to your router and only your computer can't. a. Try deleting your wireless profile. If you are using the built in wireless for windows go to Control Panel> Network Connections right click on Wireless Network Connection and select View Avaliable Networks. On the left hand side under Related Tasks click on "Change the order of preferred networks" select your network name and click remove. Now try reconnecting to it. Be sure to type in the correct security key. b. Disable your software firewall. 6. If you can connect to the router but not the internet. a. Click Start > Run type CMD into the box and click OK to open a command prompt.
At the prompt type netsh winsock reset catalog
This will Reset WINSOCK entries to installation defaults
When the first one is done tyoe this netsh int ip reset reset.log
This will Reset TCP/IP stack to installation defaults
Reboot the machine. b. Change the name of your wireless network (SSID) c. Change the wireless security key and or wireless security type. Some devices are not compatible with the WPA encription. be sure to use a HEX password Hex is 0-9 and A thru F only. The Hex key
must be exactly 10 characters long for WEP64, or 26 characters long
for WEP128. If you're using 5 characters or 13 characters, it's
really ASCII, not HEX. Please don't forget to rate this solution.
Posted on Jun 15, 2009
All of a sudden my wireless connection can't be picked up by my laptop
make surenotebook has the light indicating WIRLESS connection, also, are the hispeed modem lights on ?
Oct 22, 2010 | Blitzz Technology BWA711 Router...
Need drivers for blitzz bwa711 wireless firewall router
Router doesnt require driver to be installed on a computer to work. For getting into the settings or web configuration page type http://192.168.1.1 on the address bar of Internet explorer or any available web browser and you can configure it.
Jan 22, 2010 | Blitzz Technology BWA711 Router...
How do you reset a Blitzz BWA711? We are unable to get into it by browser and neither laptop can see a signal from it.
Remove the power cord and press the reset button with a small pin or paper clip. The reset button in recessed in a small hole just below where you would plug the modem cable in.
Dec 23, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Set up password on blitzz bwa711 router
Login to the default router config page from your desktop pc. This is usually plugged straight into the router via a network cable. Go to http://192.168.1.1 in w web browser. Default login is usally "Admin/Admin" or "Admin/Password" keep trying different combos.
You may also need to press the "Reset" button on the back of the router.
Nov 25, 2009 | Blitzz Technology BWA711 Router...
Getting Blitzz BWA 711 wireless router configured in my computer
Hi I need the router settings for BWA711 do you know what it is . Thank you, Linda
tnlmyers@comcast.net
Dec 24, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Router
i asssume that you have connected the ethernet port of the modem to the wan port of the router. if that would be the case, yes you need to connect the computer to the lan port of the router to get internet access. that it if you want your computer to be directly connected to the router. but if you're planning to connect wirelessly, you just need to make sure that your router and computer have a wireless capability and your computer.
Jul 04, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Blitzz super g 108 model bwa711
So I try search with factory thw your wireless new driver for windows vista. Issues you have only 54 g because pc´s has wireless not same 108 super g.
Good luck.
Mar 22, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Blitzz BWA711 connecting with game consoles
wel becouse the modem is older than the new ones and the conection would no longer be recieving upgrades,even if you conected the ps3 or your xbox you would not have a strong enough conection to be able to play online peacefully i recomend u get braodband wit 3-7 meg connection and then u should have no problem conecting either console to your router/modem
Mar 08, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Xbox360 connection problems
It appears we need to buy a different router. There is no way to change the MTU on the Blitzz BWA711
Nov 01, 2007 | Blitzz Technology BWA711 (B3WL000900)...
Blitzz Technology BWA711 Router (b000220deo) Logo
103 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
didi2005
JP Services
JP Services
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
