My Sanyo ac outdoor is overheating and then goes off what could be the problem
    Guru:
  • 588 Answers
If the unit is overheating, I'm assuming the compressor is getting hot. It could be drawing high amps, do to a bad capacitor, bad motor, a dirty condenser coil. It also could be low on refrigerant and not getting the proper cooling back to cool the compressor.
Posted on Jun 30, 2014
What to do with carrier infinity ac fault code 81
"Low capacity thermal lockout"#81. What this tells me is your 1st stage cooling(low capacity) is locked out for 4 he's due to a dirty outdoor coil, weak outdoor fan motor run capacitor, slow outdoor fan motor, overcharged with freon, restricted or short cycling outdoor airflow(overheating), damaged discharge temp switch, faulty outdoor circuit board. That's all the scenarios I can think of for now. Hope this helps!
Aug 24, 2017 | Carrier Heating & Cooling
After turning the AC unit on roughly 10-15mins. outdoor unit turns off head unit still on
It sound like you have problem with compressor overheated. Make sure your is clean and correct amount of freon
Nov 06, 2013 | Fujitsu 18C1 Air Conditioner
AC Starts normally but after some time of coolinf compressor in outdoor unit trips. Compressor running light in indoor unit remains on and outdoor unit fan remains on. But no cooling. After a break of...
Probably overheating. Check the outdoor coil and see if it is stopped up with dust, grass etc. If so, disconnect power to the unit, and clean the condenser coil with water or air. Be careful not to bend the fins if you use a water sprayer.
Apr 11, 2011 | LG Heating & Cooling
What does error code po5 on a sanyo cassette air con mean
P05-Current value sent from MDC on outdoor unit control PCB is low. No AC power input for 3
minutes or longer: pre-trip - 5
Solution:
1. Check R/S/T power.
2. Check inverter control PCB.
3. Check outdoor unit control
PCB.
Thanks.
Feb 11, 2011 | Sanyo Heating & Cooling
We undertake annual maintenance contract for Sanyo VRF air conditioner at standard charter bank nepal ltd., we have found the AC dose not function as well now. The fault shows as E4 on remote control. Now...
E04Indoor seeing error from outdoor. Qty of i/d units connected are less than qtyset. Check; all i/d units are ON,
reset turn off all units wait 5min power up
Helpful?
Jan 28, 2011 | Heating & Cooling
Ice on valve of Sanyo c1251 outdoor unit
Make sure you air filters are clean then make sure your fans (indoor and outdoor) are running. If these are OK then you need to get your refrigerant charge checked.
Jul 04, 2010 | Sanyo Heating & Cooling
Problem panasonic H16
Pls. check the thermostat setting. It has a setting equal to the outside temperature of -2"C. If this can still be lowered down, then I believe that it will keep your Panasonic H 16 working without interruption. You are
definitely right, your AC is working normally.
Jan 04, 2010 | Heating & Cooling
When you are watching on projector sanyo PLV-Z2 it goes off and
overheating. possible fan malfunction. clean out the projector with canned air. dust keeps in the heat.
Oct 24, 2009 | Sanyo PLV-Z2 Multimedia Projector
Some times AC blows hot/warm air
Not sure which model you have but i would check your indoor and outdoor temperature sensors  and also it could be your overload kickin the compressor off
Jun 11, 2007 | Sanyo STW0923H2 Thru-Wall/Window Air...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
