Question about Salton Wine & Spirits
Can't find model # online
I am trying to figure out how to use the ex 96 , it was given to me but did not have the instructions .
Lost charger plus instructions for casio 9.1 camara Ex-Z85A+31014870A
Instructions are often easy enough to find online on Casio's website.
http://support.casio.com/manuallist.php?rgn=1&cid=001
Choose your model number from that site and you should be able to access the online manual. If you are looking for a new charger, best bet will be to order one online or try and fine a third party one from Best Buy or similar store.
Mar 02, 2011 | Casio Cameras
1996 Grand Cherokee keyless entry problem
That remote should not be able to  be programmed by you, it needs to be programmed by the dealer using their computer.  I know that some later and earlier models can be programmed by the user, but I did some research on this as i have a 96 as well and it seems the 96 was a dealer computer thing.  If you in fact bought the remote from the dealer they should be willing to program it for FREE.  Otherwise I was given a $30 estimate for the programming.
Dec 07, 2008 | 1996 Jeep Grand Cherokee
Hello
You need to change a setting in the mode menu.
Change exact/approx to approximate and your answer will be given in decimal.
Jun 12, 2008 | Texas Instruments TI-89 Calculator
Salton Model # 17
I think I've figured my yard sale EX 80 out. First, the way I think it works... in the tightly sealed boiler the water is heated to boiling, it must have a pressure release valve that sends the water/steam through the coffee and into the carafe. So dangerously hot and under pressure. Before opening the big round cap at the top (reservoir) relieve pressure at the steam tube valve (right side)
Here's how I made my first batch:
When opening reservoir always turn unit off, let reservoir cool a little between batches or you may get a cloud of steam in your face when pouring in water, might not be good for the heating element to shock it with sudden drastic temperature changes either.
Cleaned by running a couple of jugs of water through, cold water (4 on the supplied jug) into the reservoir all parts installed. I read somewhere online (not specific to any machine) not lukewarm water, if it's online it must be true... right?
Put coffee into filter basket/basket holder, matching amount of water in reservoir, 2 or 4 (markings on filter and jug). Espresso coffee should be very finely ground
Install all covers and the coffee basket/filter basket, close steam tube valve, install carafe and turn on the machine. Should get blast of espresso after a couple of minutes.
The steam tube (operated by the valve) seems a little cheesy on first try but I'll get better with practice. There's no steam to the tube until the reservoir starts to send steam to the coffee, the coffee kinda restricts the steam enough to send it to the tube. I was thrown a little because I didn't get steam when I was cleaning the thing, but I think that was because there was no coffee to block the flow. So I opened the valve at the start of the brew, steamed the milk, closed the valve and then the steam blasts through the coffee, tasted good.
Great $1 find.
Hope this helps.
Apr 27, 2008 | Salton EX80 Espresso Machine
Wine & Spirits Logo
Top Salton Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Salton Wine and Spirit Expert? Answer questions, earn points and help others
