I have 5 computers that connect to my router wirelessly. 4 of 5 work fine. The fifth connects to the router, but can't connect through to the internet. What gives?
  • johnccooper Jun 15, 2009
    I have 4 of 5 computers connected to my router. The fift shows the wireless connection but can not get broadband access. Is there a common issue in this situation? Is there a common debug path I can follow to resolve? Note that I have tried both a wired and wireless connection to the router, so I think the issue is in my Windows XP configuration versus the connection. I am thinking that I may need to modify my networking device properties or something of that nature.
    Genius:
  • 1,269 Answers
Try to disable any firewall on that computer like norton firewall, mcafe firewall, zone alarm and the likes. If that didn't work. Check the TCP/IP properties if its using static IP. Just set it to Obtain IP Address and Obtain DNS. Then restart the computer. Or it could only be a browser settings. On your Internet Explorer click on Tools>Internet Options>Connections>LAN Settings, make sure nothing is checked on there. Click ok all the way out then try if you can go online.
Posted on Jun 15, 2009
  • 2,071 Answers
Just try to interchange only the computers not the connections, one of the four computers functioning to the fifth computers not functioning.To ease the suspection if the computer function properly, If not then you better refomat the OS of that computer.After refomatting then connect again the computer.If ever all five computers working properly even you interchange then the trouble is in the wireless connection .You better review the step procedures in wireless connection maybe you have something omitted.
Hope it may helps:
Regards:
VOTIT
Wired connection randomly drops
Since the wireless works fine on your router, then it is possible that there is a problem either on your ethernet cable or on the port of the belkin router.
Try a different ethernet cable. (Ethernet cable is the one that is connected from your computer to the router.) If you don't have a spare cable, you can directly connect the computer to the modem, just to isolate the issue and determine if it is the cable or the computer itself.
If you have determined that the cable is working fine, then try a different port on the router.
I hope this helps!
Jul 24, 2010 | Belkin F5D7234-4 Router
Wireless router not connecting
Make sure that your laptop has it's wireless network enabled and the switch if any is turned on.
Jan 12, 2010 | Belkin (F5D7231-4) Wireless Router
Belkin G Wireless router not connecting to net
Did you save the IP addresses ?You may have to configure the router manualy go to your network ,settings or type in run box IP config and see whats going on
Dec 27, 2008 | Belkin (F5D7230-4) Router (587009)
No internet signal from router
To isolate the concern, it would be better to test the non working computer to the modem. If it works, that means there is a problem with the router and if it isn't then it is a problem with the pc..
If the computer works fine on the modem, you can try the following to check if the router works fine:
1. The modem should be connected to the router's WAN/Internet port.
2. The computers should be hard wired to the router's numbered port
3. On the router's setup page, go to the Status tab and check if the Internet IP address and the DNS are populated. If not, that means the router is not functioning correctly.
4. Go to the wireless tab and make sure that the SSID is customized. Make sure that the wireless computer is connecting to the said SSID.
If those had been checked and it still does not work, you can try updating the firmware of the router, reset and reconfigure it.
However, if the computer does not work on the modem. You may need to have it checked.
Sep 05, 2008 | Linksys WRT300N Wireless Router
Worked Fine and then my computer did not recive a wireless connection, and nao cant play my 360 :[
make sure the wireless part of the router is working fine by trying a computer to connect wirelessly to the router. if it connected fine then it is a matter of matching the wireless settings of the router and the xbox in order for them to synchronize properly.
Jul 02, 2008 | NetGear RangeMax WPN824 Router
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Connecting to secure network
when enabling wireless security the router and adapter must be both be configured and configured in a fashion that both support. If you need help provide confirmation of your wireless router's manufacturer and model and the same information for any wireless adapters or computers with built-in wireless adapters to be wirelessly connected.
This will allow us to determine the common security options for all wireless devices you have.
Dec 16, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Zyxel will not connect to my laptop wirelessly
Step 1 - If your laptop contains an ethernet port for a wired connection -- connect it to the router using a wire. Try to use the internet -- if it works we are assured the router to the internet is correct.
Question 1 - Please respond to this with the make and model of your laptop and if you have one the make and model of wireless adapter for use with the computer.
Question 2 - Was this router originally purchased new or used?
Question 3 - Has this router work wirirelessly with any other computer you know about?
Question 4 - Have you configured this router since you got it?
Question 5 - Have you had someone else configure this router since you got it?
Dec 07, 2007 | Zyxel Prestige P-330W Wireless Router...
No connection
One thing to check is to make sure your dad connected to your wireless environment because so many people have wireless routers today he may have accidentally connected to a neighbor, and the low/non-existent signal strength will cause him to not have an internet connection. Also make sure no one messed with the router configuration because there is an option to turn off the wireless capability of the router. If it got turned off then turn it on and you should be good to go.
Aug 28, 2007 | D-Link AirPlus DI-614+ Wireless Router
Computers & Internet Logo
Alun Cox
David Payne
David Payne
