SOURCE: smeg oven SE399X/5 - digital clock issue
I'm glad I'm not the only one either - in the end I bought new buttond from smeg service/parts centre on their website. I took apart the front of the oven and re-seated the clock. I pushed in the new buttons and now its all ok. My problem was that because the clock had mis-lodged the buttons were touching the metal at the front of the oven, and like you when the grill is on the metal gets too hot and melts all the buttons. So the clock has to be in exactly the right place or it will melt the buttons so much that they will not press in...what a bummer!!! :-)
SOURCE: display 11
hey, i have a dacor oven that DOES show a falt code and book says it's element relay circut failure, do i have to replace the circut relay board??
SOURCE: GE JRS04BOW3BB Will not turn on.
turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
[email protected]
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
