Question about Vizio P50HDTV10A 50 in. Plasma HDTV
R/o faucet weep hole has a vacuum issue
After changing the two carbon filters, I am hearing a sucking sound at the faucet weep points, both at the backside of the faucet base and if I cover that spot then sound comes from the point where the flexible r/o drain line connects to the fixed sink plumbing. what is causing the vacuum?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 180 Answers
Try installing a check valve, or back-flow preventer. Also try getting all the air out of filters, they may have a purge valve or small screw to remove air from system.
Posted on Apr 17, 2014
Makes loud sucking sound from the side hole
It probably has a clog or restriction somewhere. The sucking noise you hear is likely the suction release valve. You will need to trace the airflow path from Motor to floor to locate the obstruction.
Mar 10, 2015 | Shark Vacuums
Electrolux el 7020 Canister Vacuum shuts of continuously do i need to Change the Carbon Brushes
How old? If fairly new you should not need brushes, bad brushes would probably not allow the vacuum to run at all. Last time you changed filter? Sounds like the cover to the filter is not closing well enough. There's also possibility you have a clog in the wand or hose.
Mar 05, 2015 | Electrolux EL7020 Bagged Canister Vacuum
Undercounter r/o water filter vacuum
Water flowing past a hole (or connection) in a pipe will cause a vacuum at that connection. Is there water flowing anywhere else in the system?
Mar 24, 2014 | Plumbing
Try purging air from filter, read instructions to find purge valve, if none try running water and air should purge naturally
Mintcraft kitchen faucet # 630-553 leaking from small hole in back of faucet
The hole is very small in the tail pipe and when you throw food, grease, it clogs this hole either partially or fully. When this happens then the water runs all over the sink through the weep hole. Which is the worst design I ever seen. By hand unscrew the black compression nut. Get a pipe cleaner or piece of wire, clean out the tube and especially the drain saddle. Reassemble and problem should be fixed.
http://www.ibathtile.com/bathrooms-kitchens/Hansgrohe.html
Sep 14, 2011 | Vacuums
WILL NOT DRIVE DOWN THE ROAD
intake sucking air or vacuum leak get a can of starting fluid crank the engine spray where you hear the sucking sound the most if the engine speeds up that s were the leak is
May 08, 2010 | 2004 Chevrolet TrailBlazer
Vacuum gets hot loses suction and turns off
you have replaced all three filters?
if its turning and sucking with all new filters you have a glog somewhere
Apr 23, 2009 | Filter Queen Majestic Canister Vacuum
My Culligan RO faucet has an ''air gap'' leak. How do I clear the clogged debris causing the water to constantly run? Culligan told me that the Faucet/Air gap is clogged. Need to dislodge the debris.
Normally when it leaks out the weep hole the drain line is plugged under the sink....turn off the ro to where it's not making water, disconnect the drain hose and flush it out....make sure the adapter that's connected to the drain pipe is still lined up with the hole if it was moved the water can't get to the drain.
Mar 17, 2009 | Culligan Under Sink Water Filter
GE smartwater R.O. system making noise from hole on side of fauce
Probably some gunk clogging the drain line. First step would be to remove the drain line from underneath the sink and check to see that it is clear. If it isn't, the next thing that may happen is when it gets completely clogged, water will start shooting out of the weep hole. As an added measure< i would say to force compressed air down the weep hole to clean out any clog in the line that you can't reach.
Feb 13, 2009 | General Electric Profile Smartwater Ultra...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
