Question about Kenwood Car Audio & Video
Kdc-hd54u troubleshooting Radio is stuck in demo mode. It will not alow me to eject CD, adjust volume, change stations,etc...The reset button has been puched and held up to 10 seconds but nothing happens. The raio will sometimes just black out as it there is no power.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Unplug the battery see if that helps.
Posted on May 19, 2014
SOURCE: Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Posted on Aug 23, 2007
simplemitch
  • 752 Answers
SOURCE: How to turn off this blasted DEMO mode on MP235
Once in standby you have to press and hold the button to get into the menu. Once in the menu, you use the joystick control on the right to navigate to "Demo" and toggle it to "off" (can't remember off the top of my head... you either have to press the joystick in and hold it to toggle or just move it up/down...). Once done, just press Source to exit.
Posted on Sep 11, 2007
  • 108 Answers
SOURCE: system lights up - stuck in demo mode - sometimes CD player plays
if detach face may not be making good contact try removing wipe connections w/rub alchol and put back on
Posted on Mar 26, 2009
SOURCE: stuck in demo
I had the same issue and was about to give up.
cleaning, key combos and such didn't work out.
Solved the dirty way, as described some comments above:
"Just took the faceplate from the "push-menu" button and hit it against a hard surface [not too hard but not too soft hits] and thats it, it worked again."
ah, the good manners!
Posted on May 07, 2009
SOURCE: Stuck on Demo Mode
Mine did the same thing, I just took the face plate off and replaced it a couple times, and magically a couple days later it starts working. It does this to me at least once a month, its very irritating. Apparently its a common problem for this model, and as of yet I haven't found any other way to fix it except just waiting for it to start working again. I've decided to scrap mine and buy another player.
Posted on Nov 12, 2009
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Every Button Switches Between Radio and CD
Reset the radio by pressing a sharp object (pin, pen, etc.) into the small reset hole on or behind the face. If it doesn't have one, disconnect the negative cable from the battery for two minutes and reconnect. If you still have this problem, the radio is bad.
Apr 18, 2014 | Panasonic CQ-DF203U CD Player
How do you remove the demo mode from a kenwood kdc-mp728 Car Stereo?
put the radio in standby mode by pressing the source button, hold the menu button, and then scroll thought the options untill you find Demo, then press volume but to turn off.
Feb 17, 2011 | Kenwood KDC-MP728 CD Player
Setting the clock of JVC KD-G125 does anyone know what and how?
to adjust the PSM (preferred setting mode) items, press and hold the select button (SEL) for 5 seconds..you should see one of the items DEMO (default item) displayed on the display window..press the Up/Down or Forward/Reverse buttons (^ or >>| or |<< ie.. it is the one you use to change the radio stations) to scroll to the PSM items DEMO-->CLOCK H-->CLOCK M-->L/O MODE-->AMP GAIN...when the PSM item you want to adjust displays on the window, CLOCK H for hours or CLOCK M for minutes for this case, use the control dial (volume knob) to change the setting...after adjusting the correct setting..press the SEL button again to end the procedure
Sep 06, 2009 | JVC AM FM CD DET FACE CAR STEREO
Stuck in demo mode. how do i change it?
Hello jayme84,
To cancel "DEMO" mode on the JVC:
Enter the PSM (personal settings mode) and turn DEMO off.
1) Press and hold "SEL" until the display changes.
2) Use the left/right rocker switch until "DEMO ON" is displayed.
3) Turn the volume knob to select "DEMO OFF".
4) Press "SEL" to exit.
Hope this helps.
Apr 28, 2009 | Car Audio & Video
System lights up - stuck in demo mode - sometimes CD player plays
Mar 26, 2009 | Aiwa CDC-X444 CD Player
Demo mode Kenwood KDC-237
To turn off the demo you need to press the src button to put it in standby mode. Then press the menu button as if to change the settings and use the joystick to scroll right until you see demo, then turn it to off....
Do as above to allow you to enter AUX mode this will let you plug in your MP3 player to the input on the face and hear music through it ;)
hope this helps you
philzee
Mar 18, 2008 | Car Audio & Video
Kenwood CD player KDC-MP825
Some units have a reset button, have you tried to reset the unit?
Feb 10, 2008 | Kenwood Sirius KDC-MP825 CD Player
No response from the KDC-519
I once had the same problem and took it in to have it looked at! The guy simply pushed in the small black button to the left of the ATT button and it reset!
Hope that helps!
Sep 04, 2007 | Kenwood KDC-519 CD Player
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
