Question about Ecoquest Fresh Air Air Purifier
Unable to remove real panel
Pressin g the sides of the panel does not relase the latches
    Problem Solver:
  • 33 Answers
I need to know what model purifier you have so I can better help you. Maybe a pic?
Posted on May 11, 2014
Dryer display blinks on ND OFF WHEN TURNING DIAL or pressing start and does not turn on
I appreciate your post, friend!
From the information you have provided your Electrolux dryer's displays blinks on and off when you turn the dial and it does not start. This sounds like a possible issue with your door latch or control panel. I would recommend for you to check the door strike and door latch to make sure there is no visible damage. If you do not see any damage this could be a wiring issue within your door latch or control panel. This is not a simple DIY job and I would suggest having a professional out to perform an accurate diagnosis. I hope this is helpful information. -Matt
Mar 01, 2015 | Electrolux EIMGD55I Gas Front Load Dryer...
Once we leveled our Electrolux slide in gas range, using it's feet, it created a gap between the left side and the countertop. Is there a filler (removable when necessary) we could use for th
Thank you for your post, Wendy Berg!
I understand that you are searching for a filler piece to go between your Electrolux range and countertop. I was unable to locate any type of filler piece I see the manufacture has a side trim kit, rear filler panel, and backguard kit but nothing specific to your request. I hope this information is helpful. -Matt
Sep 27, 2014 | Electrolux EI30GS55LW | 30" Slide-in Gas...
Unable to remove back panel
Did you get it opened? The customer service people at the home office are very helpful. Call them at 800.989.2299 and press 4. If you need further assistance or any parts, you can email me through my site.
Vollara Home
Mar 24, 2014 | Ecoquest Fresh Air Air Purifier
There are two Philip screws located on the edges of the back. Remove them this will allow the back to be taken off. Then remove the two screws at the top bracket that holds the filter in place..Ypu can remove the filter and bracket No need to remove any more of the screws on the back . From there you will see the plates and another filter. You can get at them by removing the two screws on the left and right of the plates..You can take the plates and filter out for cleaning and change the bulb if needed....NOTE; the filter on the back is resting on a activation switch just make sure when replacing the filter and bracket is pushed down to activate or the machine will not work..good luck....
How do I remove the top of my filter queen air defender 400
check around the top base closely,there is probably a small clip that needs pressed that latches it in place,most likely a twist off motion on the top piece.hope that helps you.
Mar 06, 2013 | Air Purifiers
How i can change the cab filter from daewoo nubira 2
Your owners manual should show the location and exact procedure for removing them to change them. They should be located up near the air inlet in the cowl, which would place them in the vicinity of the door pillars on either side- in the airflow of the entering air. If you already have the replacements, look for a removable panel (with 2 or 4 screws) slightly larger than the filter is wide and slighly longer than the filter is tall.
Feb 04, 2012 | Air Purifiers
Dust filter has indicated extreme level of dust for several days making the fan stay on high. any way around having it professionally repaired?
- Remove the top two screws from the control panel.
- Remove the control panel. Be careful not to pull to hard as there is a ribbon cable taped into place.
- If the ribbon cable is taped, remove the tape and set down the panel as to not put weight on the ribbon cable.
- On the top left side of the unit (behind the dust sensor), there is a small box that is held in by a screw and plastic clips. Remove the screw and put tension on the clips so you can remove the box.
- there should be two holes in the box (one on each side), use a cotton swab and alcohol to clean outside and inside the box. I reached inside with the wet swab as far as it would reach.
- While you are in there, take some time to remove as much dust off of the front panel and anywhere else it may be.
That did the trick for me.
Dec 24, 2010 | Kenmore EnviroSense 85501 Air Purifier
How do you replace batteries in freshair remote control . i cant get the back off the remote control.
For the Fresh Air 2.0 or 2.1 remote, its oval shaped.
1. Hold the remote so that that the power button is facing up.
2. Then flip the remote in your hand so you can see the back side.
3. Then with your other hand, side your index finger from the top down the back side of the remote until you finger nail catches the a slot (about an inch from the top of the remote). Right below that slot, is a plastic tab that secures the battery cover. Using your finger nail, pull that tab down about 1/16" away from the remote to unlatch the cover.
4. Lift the cover off the remote, and you should see 2 AAA batteries. Remove the old batteries and replace with 2 new batteries.
5. Align the two tabs on the battery cover into slots on the back of the remote.
6. Gently press the back cover and the latching tab should shap into the remote.
Hope this helps.
Jun 14, 2010 | Ecoquest Fresh Air Air Purifier
HOW TO REMOVE FRONT CONTROL PANEL IN ECOQUEST AIR PURIFIER
behind the front panel fingerboard on each side there is a screw hidden. You have to very slightly and gently with a fine bladed knife pry up those left and right sides to expose the screw. Its a thin piece of plastic covering the screen. Be very careful because there are electronics imbedded in the fingerpad that you are prying up. Gently lift the sticky covering only enough to get to the screws. It can be done but be careful.
Apr 13, 2010 | Ecoquest Fresh Air Air Purifier
Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Aug 04, 2008 | PUR (FM-9500) Air Purifier
Ecoquest Fresh Air Air Purifier Logo
54 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
