Question about Kenmore Refrigerators
Replaced defrost heater and keeps going out
I have replaced defrost heater 3 time now and keeps burning out why?
  • 44 Answers
Getting to hot or on too long ? Have you replaced the defrost terminator and defrost timer ? Are the heaters wired in series with the heavy coil on the bottom ? Need more info ?
Posted on Mar 25, 2014
22yooper
  • 828 Answers
SOURCE: GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Posted on Apr 30, 2008
  • 74 Answers
SOURCE: I have to keep defrosting
it may be the heater safety cutout stat that has stuck open
Posted on Aug 28, 2008
  • 4 Answers
SOURCE: keeps freezing up after replacing defrost heater
you need to replace the defrost board. its the board at the back, on the right hand corner at the bottom of the fridge. this is not inside it's outside on the back of the fridge. this controls defrost system.
Posted on Apr 15, 2009
  • 56 Answers
SOURCE: My defrost heater & bracket keeps goin out I replaced it twice
when you replace the heater DO NOT touch the glass tube, doing so will burn out the element prematurley
Posted on Feb 07, 2010
aasc
  • 1606 Answers
SOURCE: GE model #GSS201EMBWW is not defrosting, checked
This is how the defrost works . I have NEVER found a defrost problem associated with a bad main control board since these computerized GE's came out in 2000 . Lots of thermistor problems , lying to the board , causing different problems .
Your GSS model refrig does not have a defrost timer . It works off of the main control board . Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Aug 31, 2010
GE model #GSS201EMBWW is not defrosting, checked defrost heater and it was burned out. Replaced with new 2 heater design and now it burns all the time, which is most likely what burnt the other 1 out....
Aug 30, 2010 | GE GSS25SGMBS Side by Side Refrigerator
The coils in the freezer compartment keep freezing over causing the refridgerator temp to rise
Most times the defrost heater and defrost thermostat need replaced. manually defrosting, removing rear panel in freezer, unplugging power from wall and using a hair dryer to remove the ice allows you to visually see th defrost heater burned out. I will get some photos and links and return soon, Thanks Sea Breeze
Apr 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our refriderator (GE Profile) keeps losing its cool. Even though we have it set to -6 degrees for freezer and 34 degrees for fridge, every month or so it warms up to 45-50 degrees on the fridge and 25-30...
With a Profile the problem is most times the defrost heater has burned out.I have yet to see the control board be the reason. Look into rear of freezer on rear panel if not defrosting it will have a frost line creeping up the panel wall. The defrost heaters for your model have glass tubes surrounding the heating element and most times one you get the ice melted away yo can see black marks inside glass where it burned out. So if you want to do this yourself unplug and remove the rear panel and defrost with a hair drier to speed things up. It may take about two more days before this begins so plan on saving all you can somewhere else. I know, yea right! Anyway things could be worse. I will list the parts you will need and contact info, Thanks Sea Breeze
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Feb 06, 2010 | Refrigerators
GSS201EMBWW Unit is freezijng up.
Most likely part number WR51X10101 Defrost Heater has burned out. Unplug and remove the rear panel inside the freezer. Defrost with a hair dryer and examine the defrost heater and look to see if burned out, It has a glass tube around the heater element and will be easy to see if burned out. If you need to replace the defrost heater you should also replace the defrost thermostat part number WR50X10054 If you don't see a problem with the defrost heater and I will instruct you on how to manually defrost to test the heater and defrost thermostat. Check for bad connections on wiring to heater and defrost thermostat. Your model has a mother control board part number WR55X10942 We may also need to check that because it does the thinking and determines the time for defrost. Let me Know what you find, Thanks, Sea Breeze
Oct 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE GSS25JFMBWW refrigerator is not keeping cold on the refrigerator side, but is keeping pretty cold on the freezer side? Any idea on what is happening?
Sound like your refrigerator is experiencing a defrost problem. Mot times this involves the defrost heater part number WR51X10055 Look into the back wall of the freezer compartment and if frost is beginning to stick to the back wall unplug the refrigerator and remove the rear panel in the rear of freezer. Defrost with a hair dryer until you can see the defrost heater below the evaporator coils. If burned out it will be easy to spot because the defrost element is inside a glass tube. The defrost thermostat could also cause this problem if defective. If you replace the defrost heater I also recommend that you replace the defrost thermostat part number WR50X10054 There is no defrost timer on your model. Defrost is controlled by the mother board, Let me know what you find, Thanks, Sea Breeze
Sep 26, 2009 | GE Refrigerators
Freezer defrosting then freezing again...any suggestions
I believe your defrost heater inside the back of the freezer compartment rear panel has burned out. Unplug remove the panel and get a look at the defrost heater. If burned out it will be easy to spot because yours has a glass tube around the heating element inside. Let me know what you find, Thanks, Sea Breeze
Here is a photo of your defrost heater part number WR51X10055
If you replace the defrost heater you should also replace the defrost thermostat part number WR50X10054
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 29, 2009 | Hotpoint HSS25GFP Side by Side...
GE refrigerator model GTH22KBRARWW will not keep cold
Very possible that the defrost heater is burned out. Unplug and remove the rear wall in back of the freezer. If frozen over defrost with a hair dryer or let a bucket of hot water sit inside the freezer for a while. After defrost we need to inspect the WR51X10038 or 880036 Defrost Heater to see if it's burned out. If yes the you will need to replace the heater. If we find nothing wrong inside the freezer then we need to have a look at the mother control board. I will help you go through these test if you want, Let me know what you find, Thanks, Sea Breeze
Aug 21, 2009 | GE Refrigerators
MY GSS23QGT JUST STOPPED WORKING
WR55X10942 is the part number for the main control board . The fan and heater have nothing in common . After you replaced the heater , did you defrost the coils with a hair dryer , or replace the heater and let it defrost it itself ?If you let it defrost itself , the heater could burn out again for being on too long .( this happened to me once , from then on , I defrosted with a hair dryer completely before restarting refrig . Main control board controls the fan . I've never had a bad fan motor , always been the board causing the fan not to run . The main control board will run about $150.00 if you install it yourself .
Aug 16, 2009 | GE GSS23QGT Side by Side Refrigerator
Not Cooling Fridge Or Freezer keeps Freezing up (New Defroster)
There are 3 parts to the defrost system,Which did he replace? You should ask and don't name the parts for him,Let him tell you what he replaced.Here are the 3 parts to listen for.
Improper installation,a faulty part,or a short could cause it to fail in that short time.
  1. Defrost timer
  2. Defrost element
  3. Defrost thermostat.
Any other question, feel free to ask
Please rate this a fixya
May 18, 2009 | GE Freezers
Refrigerators Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
