Question about Equity Time USA 31215 Wireless Outdoor Thermometer
Remote wireless sensor temp does not transfer to the main station
The remote unit reflects the correct temp but does not show on the main unit
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
I CANNOT GET MY OUTDOOR TEMP, TO CHANGE, HAS NEW BATTERYS AND POLARITY IS CORRECT. PLEASE HELP, THANX
Hi Jim, what make/model station do you have? Normally there is a search function on the main unit to find the outdoor unit. After that they should sync and the outdoor temperature will reflect the temperature of where the outdoor sensor is located.
Hope this helps.
Nov 15, 2014 | Measuring Tools & Sensors
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
Changed batteries and the outside temperature still does not show
Bring the outside sensor inside. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the remote sensor. Put the batteries back in the main unit. Do not touch any of the buttons. Wait 10 minutes. If the remote temperature is not showing within 10 minutes, try again. Once the remote temperature is showing, you can set the clock.
Jan 08, 2011 | La Crosse Measuring Tools & Sensors
Cannot get the outside temp to respond on a WS9047U-IT
Bring the outdoor sensor indoors. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the outdoor sensor. Put the batteries back in the main unit. DO NOT PRESS ANY BUTTONS. Wait 10 minutes or until the outdoor temperature shows. Once the temperature shows you may use the buttons to set the clock, etc. If it does not show after 10 minutes, then try again.
Jan 07, 2011 | La Crosse Measuring Tools & Sensors
I have a Sharp SPC502 atmoic clock/weather station. No matter what I do I cannot get the outside temp/humidy to show up on the main station. Have tried changing channels, different alignments,...
Try pushing the reset button on the inside of the battery compartment of the remote unit then push the reset button on the back of the main unit (you'll need a paperclip or tooth pick to push the buttons). If that fails I'd start from scratch by removing the batteries from both the remote unit and the main unit then replace the batteries to the remote unit first and push reset, then replace the batteries to the main unit and if necessary push the reset button on the main unit too. Hope this helps.
Dec 28, 2010 | Sharp Cell Phones
How do get the outside temp to work.
Bring the outdoor sensor inside. Take batteries out of both the sensor and the main unit. Wait 10 minutes. Put batteries in remote sensor. Then put batteries in main unit. Don't touch any of the buttons for 10 minutes or until the outdoor temperature is displayed. If still not displayed after 10 minutes then try again.
Dec 26, 2010 | La Crosse Technology Wireless Thermometer...
The weather Forecast Icons don't change on my honeywell weather station model # TE852W
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 11, 2010 | Honeywell TE852W Weather Forecaster With...
Equity Time USA 31215 Wireless Outdoor Thermometer Logo
76 people viewed this question
Top Equity Time USA Measuring Tools & Sensors Experts
George Merkley
George Merkley
rich2481
Are you an Equity Time USA Measuring Tool and Sensor Expert? Answer questions, earn points and help others
