Is the 07 dodge nitro towable
SOURCE: can i change my automatic transmission to a
sure it's possible
BUT you'll need to change a few other things like the differential the computer the wiring
if your an expert with a lot of time to kill and a TON of spare cash you can do it
otherwise you'll save yourself thousands by just trading it in for a stick shift model
SOURCE: replace antenna on 07 dodge
Hi Locate the faulty antenna, which is screwed into the base on the front right fender of the truck. Unscrew the bottom portion of the antenna with a pair of channel locks. Pull the used antenna off the truck.Screw in the new antenna by hand. Tighten the antenna with channel locks. Turn the radio on to ensure the antenna is receiving the desired radio stations. Change the stations to test the range of the antenna. Please check this link for the diagram:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
