Question about Pioneer Audio Players & Recorders
What causes very very little sound
I have pioneer ax 720 for a time now,but suddenly i hear a very little sound in speakers
  • Pioneer Master
  • 5,487 Answers
Either the power amp failure or a pre-amp failure.
Posted on Apr 16, 2014
I was listening to AIWA home stereo integrate amplifierMX-D10 n suddenly no sound
If you are hearing a very faint sound from both speakers, make sure your tape button or lever is switched off.
Apr 22, 2014 | Audio Players & Recorders
Sherwood AX-4103 amp keeps clicking
Hello there.... Check your speaker wires and then if that doesn't do it? try replacing the fuses on the back of the amp.. make sure power is turned off and unplugged. If that doesn't work? Try one speaker at a time ... something is causing the system to short out. Hopefully it is not internally
Apr 21, 2014 | Sherwood Audio Players & Recorders
I just bought the tritton ax 720 headset for my xbox 360. I can't find the manual, and I need to hear my game through my headset, not just the tv. I heard something about an optical cord, but I don't know...
The AX 720's can be connected with an Optical cable but you must have such a plug on the back of your Xbox360.
If you dont have an Optical Outpun on your Xbox360 then you'll need to connect them to your TV with the green jack from the cable provided with the headsets.
The manual can be found here: http://support.trittontechnologies.com/supportsuite/index.php?_m=downloads&_a=viewdownload&downloaditemid=65&nav=0,1
Hope it helps...
Dec 30, 2009 | Microsoft Xbox 360 Console
Tomtom go 720 no sound
then its problably a fault in the main board or the headphonejack is "in" all the time...
its a little switch inside a jac hole , it canget stuck i had that problem with my laptop
Nov 10, 2009 | GPS
No sound from new stereo
check the speakers in the rear deck, in the rear hatch or trunk, often the two wires that come out of the speaker touch if that happens it will short out the speaker drivers in the radio most times no permanant damage will occur. separate the wires so they do not touch,or touch the metal speker base, that may not be the problem but its a start..
Oct 16, 2009 | Hyundai Motor 1998 Accent
Pioneer Deh-3100 CD Player/Tuner Won't eject CD. CD spins around but can't hear it because suddenly and without warning none of the control buttons function. How to fix or remove.
This might be a shot in the dark, but there possibly is a reset. Look for a little hole, about the size of a paper clip, usually with the faceplate off. Take a straightened paper clip or reasonable facsimile and gently push into hole. If this works it will reset everything to factory and you'll lose your pre-sets etc.
Aug 13, 2008 | Pioneer Car Audio & Video
CANT GET SOUND
This is often caused by a shorted speaker wire. If you have a pinched or loose speaker wire that's touching metal, it will cause the deck's internal amplifier to shut off. If you have a multimeter available, disconnect the deck then check each speaker wire for continuity with the chassis ground wire. If you don't have a meter, you can disconnect all the speakers, then connect them again one at a time. See if you can tell if there's one speaker that kills the deck's output.
Jul 28, 2007 | Pioneer DEH-P9300 CD Player
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
