Question about Ecoquest Fresh Air Air Purifier
Unable to remove back panel
Pressing the sides of the panel does not release the latches
    Sergeant:
  • 406 Answers
There are two Philip screws located on the edges of the back. Remove them this will allow the back to be taken off. Then remove the two screws at the top bracket that holds the filter in place..Ypu can remove the filter and bracket No need to remove any more of the screws on the back . From there you will see the plates and another filter. You can get at them by removing the two screws on the left and right of the plates..You can take the plates and filter out for cleaning and change the bulb if needed....NOTE; the filter on the back is resting on a activation switch just make sure when replacing the filter and bracket is pushed down to activate or the machine will not work..good luck....
Posted on Mar 25, 2014
Dryer display blinks on ND OFF WHEN TURNING DIAL or pressing start and does not turn on
I appreciate your post, friend!
From the information you have provided your Electrolux dryer's displays blinks on and off when you turn the dial and it does not start. This sounds like a possible issue with your door latch or control panel. I would recommend for you to check the door strike and door latch to make sure there is no visible damage. If you do not see any damage this could be a wiring issue within your door latch or control panel. This is not a simple DIY job and I would suggest having a professional out to perform an accurate diagnosis. I hope this is helpful information. -Matt
Mar 01, 2015 | Electrolux EIMGD55I Gas Front Load Dryer...
Once we leveled our Electrolux slide in gas range, using it's feet, it created a gap between the left side and the countertop. Is there a filler (removable when necessary) we could use for th
Thank you for your post, Wendy Berg!
I understand that you are searching for a filler piece to go between your Electrolux range and countertop. I was unable to locate any type of filler piece I see the manufacture has a side trim kit, rear filler panel, and backguard kit but nothing specific to your request. I hope this information is helpful. -Matt
Sep 27, 2014 | Electrolux EI30GS55LW | 30" Slide-in Gas...
Did you get it opened? The customer service people at the home office are very helpful. Call them at 800.989.2299 and press 4. If you need further assistance or any parts, you can email me through my site.
Vollara Home
Mar 24, 2014 | Ecoquest Fresh Air Air Purifier
Unable to remove real panel
I need to know what model purifier you have so I can better help you. Maybe a pic?
How do I remove the top of my filter queen air defender 400
check around the top base closely,there is probably a small clip that needs pressed that latches it in place,most likely a twist off motion on the top piece.hope that helps you.
Mar 06, 2013 | Air Purifiers
I want to take my ecoquest fresh air apart to clean it, but do not know how, i have misplaced the manual
Unplug the machine and unscrew the phillips head screw on the back grill of the machine, that is just above the plug. There are depressions on the sides of the back grill that has a plastic tang that hold the back grill to the machine. Press the back grill inwards to allow the tangs to clear the sidee and the back grill should now be easily removed. Remove the two thumb screws on the top corners to remove the filter. Once the filter is removed, then you can remove the purification plate and remove the two screws that hold the RCI cell. The RCI cell and filter can be cleaned by vacumming out the dust and dirt.
The purification plate can be cleaned with a old toothbrush and a water and amonia solution. Scrub the metal grid with the toothbrush. Do both sides and then rinse with water, allow it to dry completely before reinstalling the plate. After every part is cleaned reassemble the purifier, and plug it in. Then press the reset reminder button on the front of the keypad to clear the "perform cleaning" message. This message will appear again after the purifier runs for 30 days to remind you to clean the purifier. Hope this helps you.
Oct 09, 2010 | Ecoquest Fresh Air Air Purifier
How do you replace batteries in freshair remote control . i cant get the back off the remote control.
For the Fresh Air 2.0 or 2.1 remote, its oval shaped.
1. Hold the remote so that that the power button is facing up.
2. Then flip the remote in your hand so you can see the back side.
3. Then with your other hand, side your index finger from the top down the back side of the remote until you finger nail catches the a slot (about an inch from the top of the remote). Right below that slot, is a plastic tab that secures the battery cover. Using your finger nail, pull that tab down about 1/16" away from the remote to unlatch the cover.
4. Lift the cover off the remote, and you should see 2 AAA batteries. Remove the old batteries and replace with 2 new batteries.
5. Align the two tabs on the battery cover into slots on the back of the remote.
6. Gently press the back cover and the latching tab should shap into the remote.
Hope this helps.
Jun 14, 2010 | Ecoquest Fresh Air Air Purifier
I cannot remember how to take off the back of my Fresh Air. The older model of fresh air had 2 screws on the side -- this one doe not. Just a screw in the back and that one is off and still cannot take...
Just squeeze the back sides in slightly to allow the plastic tabs to release from the left and right sides of the unit. Then lift the bottom portion of the back cover first then the sides then the top to remove the back cover.
Hopes this helps.
Jun 08, 2010 | Ecoquest Fresh Air Air Purifier
HOW TO REMOVE FRONT CONTROL PANEL IN ECOQUEST AIR PURIFIER
behind the front panel fingerboard on each side there is a screw hidden. You have to very slightly and gently with a fine bladed knife pry up those left and right sides to expose the screw. Its a thin piece of plastic covering the screen. Be very careful because there are electronics imbedded in the fingerpad that you are prying up. Gently lift the sticky covering only enough to get to the screws. It can be done but be careful.
Apr 13, 2010 | Ecoquest Fresh Air Air Purifier
Ionic pro sizzles and crackles when I turn it on. it doesn't crackle constantly but, it like slowly pulses. it crackles for about a second every 4-6 seconds while it is on high, and a little less often...
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Jun 17, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ecoquest Fresh Air Air Purifier Logo
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
