Question about Dryers
Video test 3387134
Kitchen aid model KEYW977BWHO. Could not find a user manual on their website. The dryer starts and runs for about ten to fifteen seconds and then beeps about six times and shuts off for five minutes or so. My clothes aren't drying like they should. It has been taking me about 2-3 dry cycles to completely dry one load. any suggestions?
  • Dryers Master
  • 17,093 Answers
This sounds to me like the heating element is bad. You need a meter to test it. You should not attempt this if you are not comfortable with it. Unplug it and remove the front of the machine, some have kickpanels under the door that come off with little effort after two screws are removed, Others require that the top of the machine be lifted off and then the front taken off. Then you need to locate the heating element. It is mounted to the bottom of the machine. You at this point should start cleaning the unit because it is most likely covered in lint. Then you can pull out the heating element box. NOTE where the wires are connected. Then you can check to see if the heating coil is bad. You can see if it is broken or you can use a meter to test it. There are also two switches on the unit that houses the heater coil. One is a thermal fuse and the other is a thermostat., Check those too.
Posted on Mar 24, 2014
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
  • 94 Answers
SOURCE: Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Posted on Oct 14, 2008
  • 57 Answers
SOURCE: LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Posted on Jan 04, 2009
  • 245 Answers
SOURCE: 2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
Posted on May 18, 2009
SOURCE: It takes at least 2 60 minute cycles to dry clothes. Not even 2 years old yet. Not a new problem has always been this way. What is the deal.
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
Posted on Jun 15, 2009
Whisper quiet plus kitchen aid manual
Hello, As You Wish -
It looks like you can obtain the owner's manual for your Kitchen Aid dishwasher through the Kitchen Aid web site. It will probably be a download option for a PDF version of the manual. This is the link: https://www.kitchenaid.com/customer-service/manuals/ . You will need to enter the model number of the dishwasher.
Note: When I obtain a downloaded PDF user manual (for anything), I create a file in my Documents folder, giving the file the name of the product, so I can find it easily. Example: Kitchen Aid Diswasher. Unless the manual is hundreds of pages long, I also print it out and keep it in a paper file folder with other appliance and equipment user manuals.
Best wishes.
Dec 18, 2017 | Dishwashers
LEC8858EQ0 starts and then shuts off
You have a problem with the motor overheating. Replace the motor and you should be good to go. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 08, 2012 | Whirlpool Dryers
I have a Kenmore 500 model # 110.68532700, sometimes it would work and run for about ten minutes then shut off, after about 10-15 mins you could run it again, sometime it would run fine tell the clothes...
see this possibles causes:
see the diagram attached
1) Test the main start switch for open 2) Test the switch door for open 3) Test any coonector for loose wires, or broken wires, or burn .4) Motor defective repair
Jun 09, 2012 | Kenmore 500 6952 Dryer
Kitchen Aid Gas dryer KGYE664WWHI does not heat up
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at http://appliancehelponline.com/gdryertroublevideo.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Aug 03, 2010 | KitchenAid KGYS850LT Gas Dryer
My kitchen aid gas dryer is not heating up.
If it is tumbling. This troubleshooting video will help. Could be the thermal fuse,ignitor,or gas coils. The free video will walk you thru testing.
www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | KitchenAid Dryers
I HAVE CLOTHES DRYER MODEL NO. KEYW977BWHO AND WHEN I PUSH TH NO HEAT AND PUSH THE START B UTTON IT START AND THE HEATING ELEMENT STILL COME ON AND STARTS TO HEAT. DO YOU HAVE A SOLUTION TO THIS PROBLEM...
There are a few possible issues you will need a quarter inch nut driver and and ohm meter to figure out the problem. First step remove the back panel. Once your back there to ohm anything out you have to remove one wire from the device your testing. You will have a skinny white thermal fuse with two wires going to it if that has no continuity its bad replace that (3392619) and the cycle therm next to it w/ 4 wires (3387134) and check your venting because the problem occured due to over heating. The next thing is you thermal fuse located at the top of the heater housing that comes in a kit with the hi limit thermostat which will probably requere some rewiring. The last thing to check would be your heating element which is a (279827) fairly expensive but easy to replace. Also before you replace anything make sure you are getting true 240v to the dryer.
Hope this helps _MJ_
Jan 31, 2010 | Whirlpool LER5636P Electric Dryer
Kitchen Aid Electric Dryer Model # KEYE678BALO, won't start.
This is most often caused by a bad thermal fuse or thermostat high limit cutout. Check them for continuity (with the machine unplugged, of course) They should have continuity -- replace them if open. They should be available at www.appliancepartspros.com Also, if one or both are bad, check the dryer vent as they often are damaged by high heat due to a restricted vent pipe. The website above also has diagrams to help find the parts on the machine.
Dec 30, 2009 | Washing Machines
Control Lock light is on and nothing works on my stovetop
Hi. Research your stovetop on the kitchenaid website. You should be able to download a user manual for your model. The manual should tell you how to reset the lock. If a manual is not available, try disconnecting the power supply to the stove. This might clear the memory of the stove. Good luck. ricardok45
Feb 02, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Nocking motor
the motor starts nocking after about ten to fifteen minutes of running.and looks like it is overheating but i do not understand the overheating signals on the dashboard.
Jul 23, 2008 | 2001 Dodge Intrepid
Dryers Logo
Top Dryers Experts
