Question about Rowenta Is5100 1500 Watt Opti-Steam Garment Steamer
Power light does not come on when IS5100 steamer is plugged in. What's wrong?
No "power ON" light when IS5100 steamer is plugged in. What's wrong?
How can I get my steamer to work again? Orange light comes on but nothing else
Make sure you didn't knock off a wire to the heating element when you had it open. Also put a couple of cups of whitevinnegar in it and leave it for an hour or two. This will dissolve the scale build up. If it doesn't get hot thenthe element is probably burned out. There is a limit switch held against the tank too. It can stop the heating element if it goes bad.
May 29, 2014 | Rowenta IS9100 1550W Precision Valet...
Blown fuse
If the fuse you are blowing is in your fuse box in house then your steamer is using more power than the fuse can carry. Move to an outlet powered by a larger fuse. Do not recommend changing fuse to a larger amp fuse because this could cause a fire hazard.
Feb 26, 2014 | Sunbeam S1500 1500-watt Classic Garment...
My Tobi Steamer will not power on?
Check the fuse in the mains plug and replace it with a like value one. If this doesn't work your iron is at fault.
Jan 08, 2014 | Irons
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
My steamer steams and then shuts off and it takes another two minutes to steam again....what is wrong?
the power light stays on but steam only comes out for 30 second.and it takes few minutes to steam again.
Oct 21, 2012 | Rowenta Commercial Garment Steamer - White
The power to heating section suddenly went off. Is there an internal circuit beaker or fuse?
check your power cord if it has a break from the plug side.if not take it to a repair shop for repairs. the steamer has a element inside that gives off the heat if that goes bad then there is no where it can be replaced or repair.but if its the wires then repairs can be made.best way to know that is to take it to the repair shop.good luck.
Sep 23, 2011 | Rowenta Commercial Garment Steamer - White
Plugged in, reset button is lit, won't go off
The problem is the thermostat (NC 150 C). A replacement is available at Digikey.com, item R2015025 (part no. 317-1468-ND) It's a simple replacement with the bottom removed.
Apr 20, 2009 | Homedics PS-200 Iron with Auto Shut-off
On off light never shuts off
Clarification: When you "switch off" the unit, does the light stay on, but the steamer itself shut off (cools off to no steam)? If this is the case, only the LED does not light (which will not affect actual performance, other than being a "false" indicator driving some users crazy) like an Engine light that stays on in your car. It is likely a bad connection rather than a bad LED (Light Emitting Diode indicator). If the steamer portion is powered on all the time regardless of the switch position, try turning the temperature settings all the way down on the base and iron before unplugging unit to prevent the arcing (sparks) from damaging the input AC plug.
Solution: you will need a small Security Torx Bit/Driver to take unit far enough apart to inspect, troubleshoot and determine cause. You will also need an analog or digital multi-meter to check the unplugged unit' switch using self-powered ohm-out (continuity check) function, testing forward & reverse diode for lo & hi resistance reading respectively, (if you use the Rx1 range, the diode will glow slightly in one direction if it is good & you use an old analog meter). If you are so inclined or know somebody into electronics to do this, you can get these tools at Harbor Freight for $10-$20, good luck and keep in touch.
Apr 26, 2008 | Rowenta DG5030 Iron
Rowenta Is5100 1500 Watt Opti-Steam Garment Steamer Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
