Question about Whirlpool Microwave Ovens
Will not power up after power outage
My WMH31017AW-0 microwave has a strange issue. We had a power outage and once I tried to turn on only the turntable works and it works without pushing start. I shut the door and it turns on. I can't cook or warm up anything. THe clock and timer works. I went through my manual and pressed and held a few of the troubleshooting buttons it says to do and it works.??? What do I need to do???
  • 61 Answers
It contains two fuses one of 10 Amps and other for 500mA.
Replace 10Amps fuse with same type and rating.Best thing is to take this fuse and show it to the sale person of electronic shop.
Before you touch any parts of the microwave oven please disconnect the mains power chord and never touch the main power capacitor as this contains very high voltage even after disconnection.
Posted on May 18, 2014
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave will not turn off
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Posted on Aug 14, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
  • 3 Answers
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
Aug 06, 2016 | Samsung Microwave Ovens
Tip
Error Code F8E5
F8E5 Exhaust air template detection failure 1. Press CANCEL - CANCEL - START, verify failure code, and then press CLOCK/OPTIONS to display the exhaust air temperature sensor reading. Verify the sensor temperature reading is at room temperature (typically 50?F to 90? [10?C to 32?C]) and verify failure code. If failure code matches complaint, continue to Step 2. 2. Unplug microwave oven or disconnect power. 3. Disconnect sensor from ACU PCBA. 4. Measure HF NTC resistance between connector pins and confirm reading is between 9.5k??and 10.5k??at room temperature. If measurement is not correct, or if a short or open circuit is found, replace sensor. 5. Replace all parts and panels before operating. 6. Plug in microwave oven or reconnect power. 7. If the sensor temperature reading is still not correct, replace ACU PCBA. 8. If failure does not appear, stop.
on Jul 21, 2015 | Whirlpool WMH31017AW
Manual for a whirlpool microwave oven model wmh31017aw-1
There is no turntable control. It is always on. The turntable should change direction each time the unit is used. If the turntable is not operating, it has malfunctioned. Newer microwaves for the most part all have full-time turntables to promote even heating, thus reducing customer complaints about ovens that don't heat right.
Dec 30, 2015 | Whirlpool Microwave Ovens
Error Code F8E5?
see if the place you bought it wants it returned for refund and you might get some assistance.
Sep 03, 2012 | Whirlpool WMH31017AW
After a short power outage, I have clock issues.
this a problem with the clock , but the microcontroller can be defective by the power outage, see the diagram . how the microncontroller has the control for any equipment.
IN SHTE M.CONTROL BOARD CAN BE DEFECTIVE. go to the repair shop Tv FOR FIX IT. God bless you
Jul 19, 2012 | Microwave Ovens
Viking 1100 watt Microwave will not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjj
Jan 05, 2010 | Viking VMOC205SS Microwave Oven
Panasonic Microwave model # NN2505C stuck on Demo mode following power outage do not know how to return to normal function
The manual is not available on line so I do not know if this will work but try pressing FUNCTION-0-2.
Nov 01, 2009 | Panasonic NN-T655SF Microwave Oven
Microwave will not stay on.
try changing the ceramic fuse located in it
Apr 08, 2009 | Microwave Ovens
Microwave Ovens Logo
166 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
