Help
SOURCE: Whirlpool Gold Microwave Model GH7155XHS
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Microwave will not turn off
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Door
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. Other times, it's a broken tab on the switch
holder, allowing the switch to rotate just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or
handle as you try to start it. If it works or tries to work, then it's
a door switch mount or door alignment issue.
If
our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There may also
be a "mini-manual" hidden inside the unit behind the control panel or
hidden on the left side behind the grille, which is very helpful when
troubleshooting & testing.
We're happy to help you and we'd appreciate your
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
SOURCE: sharps microwave
Door
There
Sometimes
If
You can probably find exploded views and order parts by entering your model number (R-520JKF) here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
SOURCE: Microwave Oven Does Not Start Cooking
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
There are
plastic mounts inside the microwave which hold the door switches and
The screws on these
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
know decide to look
FixYa:.
number here.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a
switch, you can order a universal type here for $5 postpaid.
for $39.95 postpaid in most cases in about a week or so.
We're
i MEANT CAN'T GET THE MICROWAVE TO COOK OR WARM UP ANYTHING
