Question about Hammering
Rockworth compressor drive belt
I want a belt details are: Megadyne TB32-310
3 Suggested Answers
SOURCE: Samsung dv4006 dryer belt
After four new belts.
There is only one solution , load the dryer into a UPS truck and ship it back to Samsung . Put a note inside and tell them to stick to TV's and stay out of the appliance business .This is the cheapest solution short of filling up the landfill . Believe me this is a lot cheaper than buying belts
Cam
Posted on Aug 03, 2009
david2014ros
SOURCE: I need a other belt
go to the store and bye a new one
Posted on Mar 07, 2015
Testimonial: "What is the name and the adress in Panama where I should buy the belt???"
Why doesn't my rockworth compressor fill up when it's running it's brand new
This could be an assembly error at the company. There are three valves in a compressor, one is an intake, one is an exhaust, one is an unloader. The easiest way to check is to put your hand on the intake air filter to check for suction. If there is suction then the valve is ok on the intake, if it flutters then it is bad or missing. Locate the on off switch and there should be a valve that unloads the pressure from the compressor, see if that is leaking.
May 05, 2016 | Rockworth Factory-Reconditioned...
I need a other belt
Mar 07, 2015 | Washing Machines
Rockworth 1.5 hp 6ltr oil free compressor drive belt replacement
You could try this link.
This is for megadyne tb2 310 belt (nlh6ltCOM)
http://www.solenttools.co.uk/performance-power-drive-belts/performance-power-compressor-drive-belt-nlh6ltcom-2051157-331171-.php
Feb 19, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How do you fit a new drive belt to a rockworth compressor because there doesn't seem to be ant adjustment
if this is a small compressor say 2 hp you leave everything alone make sure you have the right size belt and stretch it on like a rubber band.. The belt will be quite tight but thats the way they come. If you are concerned that the new belt is too tight or too loose mark the position of you motor with a felt pen remove the belt and move the motor forwards or backwards a small amount in line with your marks, then refit the belt. The main thing is that the motor shaft stays parrallel or close to it with the drive shaft of your pump.
Jan 16, 2013 | Air Tools & Compressors
Rockworth air compressor
I would think that if you are mechanically inclined at all you should be able to do that. You are right must tanks are either generic in configuration or made be the same manufacturer. I would like at worse case you may have to drill a couple of new holes for mounting your compressor.
Apr 21, 2012 | Air Tools & Compressors
Where can I get a manual formy newR W 1820F
I am sorry but we do not have manuals for this type of equipment, I suggest you contact Rockworth.
Feb 10, 2012 | Cars & Trucks
I have bought an ex-display Rockworth 24 litre 2.0 Horse Power Compressor and need to source a users manual
Hi, my name is John. Welcome to FixYa. You can get it here. www.mastertoolrepair.com . Thanks for choosing FixYa...John
Nov 24, 2010 | Air Tools & Compressors
Cam
May 15, 2009 | Samsung 7.3 Cu. Ft. Electric Dryer
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: partsonline@appliancefactory.com
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Nov 06, 2008 | Samsung 7.3 Cu. Ft. Electric Dryer
Hammering Logo
70 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
