Question about Canon F-710 Calculator
How do i do dms and dd on canon f-170 calculator?
I don't know how to do the dms (degrees-minutes-seconds) and dd (decimal degrees)functions on my canon f-170 calculator. There aren't any buttons to do it. Urgent! I need help!!!
  • Canon Master
  • 8,073 Answers
I could not find the manual for the F-170. Could it be the F710?.
For the F-710 the key + doubles as a DMS-DD key. see screen capture.
how do i do dms and dd on canon f-170 calculator? - 9cd915ec-7758-4d3c-8f61-5bd79792a136.png
Posted on Mar 25, 2014
4 Suggested Answers
  • 3 Answers
SOURCE: Canon Calculator
Okay just figured this one out but on the back of the claculator there is a slip slid paper in that Press the feed key and allow the paper to feed through the claculator if it doesn't feed through push the paper in a little and hit the feed key again. It worked for me
Posted on Oct 04, 2008
  • 566 Answers
SOURCE: i want to buy the
You can sdownload it rom canon support site for free. Here is the link:
http://downloads.canon.com/cpr/software/calculator/P170-DH-(USA-HWB).pdf
Posted on Apr 07, 2011
thehappydog8
  • 50 Answers
SOURCE: I have the Canon LS-100TS
Try switching between business and tax mode, the little toggle switch at the top of the calculator.
If that doesn't work repost.
Hope that helps
Posted on Jun 28, 2011
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
How do i enter 50deg,25minutes,23seconds into a casio fx-9750 plus
In Run>Mat press the OPTN key, Then F6:> to move to the next page of options. You will see the ANGL tab as on the screen capture (above F5 key.
Press F5. You will see what follows.
Type in 50, press the F4 key, 25 then F4, 23 then F4. Press EXE. you get the result in decimal degrees as on the screen capture. To convert from DMS to D.D, or from D.D to DMS, vice-versa, press the F5 key
Jan 05, 2013 | Casio FX-9750GPlus Calculator
Dd to dms conversion
Press the DMS button to convert between decimal degrees and degrees-minutes-seconds.
The DMS button is marked with the degree, minute, and second symbols. It's located above the [ENG] key, which is located above the [8] key.
For full details, start with the "Degree, Minute, Second (Sexagesimal) Calculations" section beginning on page E-22 of the manual. If you need a manual, you may download a copy here.
Jan 19, 2012 | Casio FX-115ES Scientific Calculator
How do you enter Degrees Minutes Seconds on acasio fx-9750 Calculator
To access the DMS function, turn calculator ON, go to the RUN screen. Press OPTN F6>, F5:ANGL You will see a csreen as on the capture.
To enter an ganle value in DMS, enter the degrees, press F1, enter the minutes, press F1, enter the seconds and press EXE. the value may be displayed in DD Decimal degrees. To conver press F4. To convert back press F5 (notice the backArrow on the TAB).
Oct 30, 2011 | Casio FX-9750GPlus Calculator
I know how to convert between decimal degress and degrees, minutes, seconds, but how do you enter degrees, minutes, and seconds directly?
Enter it as DD.MMSS and then press 2nd [DMS-DD] to convert it to decimal for further calculations.
For example, to enter 21 degrees 34 minutes 45 seconds, enter 21.3445 then press 2nd [DMS-DD].
May 12, 2011 | Texas Instruments TI-30XA Calculator
How do i enter 46degrees 15minutes into my ti-36x calculator?
Enter DMS (Degrees/Minutes/Seconds) values as D.MMSSs, using 0s as necessary:
  • D degrees (0-7 digits)
  • . decimal-point separator
  • MM minutes (must be 2 digits)
  • SS seconds (must be 2 digits)
  • s fractional part of a second
For example, enter
  • 46° 15' as 46.15.
  • 179° 9' 2.54" as 179.090254, note the 0s in front of the 9 and 2.
Before using a DMS value in a calculation, you must convert it to decimal with [2nd] [>DD].
Jan 13, 2011 | Texas Instruments TI-36 X Solar Calculator
How do I convert DMS to DD with a ti84 plus?
To enter an angle in DMS format, enter the number of degrees, 2ND [ANGLE] 1 to indicate degrees, enter the number of minutes, 2ND [ANGLE] 2 to indicate minutes, enter the number of seconds, ALPHA ["], then ENTER.
ANGLE is on the APPS key, " is on the + key.
You can convert an angle from decimal to DMS with the ->DMS command, 2ND [ANGLE] 4
Jan 10, 2011 | Office Equipment & Supplies
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
HOW DO YOU USE THE DEGREES MINUTE SECONDS FUNCTION
To convert an angle from degrees (decimal degrees) to the sexagesimal notation (deg, min, seconds) use the key [DMS] the one between [(-) and [hyp].
Everytime you press the key, the displayed result is cast in the other form
EX; 12.58 [DMS] gives 12 deg 34 min 48 sec.
Suggestion: If you are doing many calculations with the sexagesimal format, use the decimal degree format, and only when you find the final result do you convert it to DMS.
Hope it helps.
Sep 30, 2009 | Casio FX-115ES Scientific Calculator
Degrees, minutes, seconds converted to decimal degrees
No DMS button
1degree 22.25 minutes
2nd Math F3 1 F1 22 f3 15 f3 enter
Sep 05, 2008 | Texas Instruments TI-85 Calculator
Canon F-710 Calculator Logo
122 people viewed this question
old marine
old marine
