Question about Sansui Televison & Video
Sansui portable tv capacitor
How many wat capacitor to sansui portable colour tv
    Top Expert:
  • Sansui Master
  • 75,304 Answers
There are so many capacitors of different capacitance, and with different voltage levels. About which capacitor you are asking about? If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 24, 2014
Videocon
Just provide more details about the fault. As a technician, you can provide more details; I assume. Gopakumar Gopalan Google
Apr 25, 2014 | Sansui SLED2282 22" Accu Series Super Slim...
Hi I have sansui tv , it's colours are going to
Check and replace the chroma IC. Before replacing it, re solder all the solder terminals to this IC, by applying a little more fresh solder to each terminals.
Sep 29, 2012 | Televison & Video
On swiching on my sansui 21 inch tv it is producing a sound gradually increasing in intensity and the screen is blank(black). any action through remote control is not being executed. wat is the problem
You are losing power in the vertical section. This will start with bad capacitors. Pay attention to capacitor (locations) C515, 25 volt@10MF, C423,50volts@4.7Mf, C407,35volts@ 100Mf, and C406,50 volts @1Mf.Please pay attention to any 50 volt 1 MF caps not mentioned. These are located near the audio IC, they are very small as the one mentioned earlier.Also, resolder the vertical IC, as there are rings around the pins at the bottom of the board. Start with these procedures and the picture will return and then sound will be stable. Be very careful when you you remove the capacitors. The traces are very small and delicate and you can destroy the TV. Once again....please very careful when you replace these components. Thanks for asking and show a few hands of support.
Dec 16, 2010 | Sansui DTV2700 27" TV
Im having problems programing my sansui flat screen tv when i program my rcr311b universal remote it works up untill the point when the tv turns off after pressing the play button and releasing the reverse...
first wat are u trying to do,,,,,,in mind....wat way,,,,,to do wat....try going to get thing that can remote w/remote to do......reverse the plan of mind,,,,
Aug 27, 2010 | RCA RCR311B Remote Control
In My sansui k2k21 flat tv showing red colour more please tell me will i replace the eht or crt
you do not have a CRT in your flat panel set.. What you might have is your color setting to high causing the bleed or your
T-con board is bad , but first turn down your color if that does not do it have a tech replace your
T-con board
Nov 19, 2009 | Sansui HDLCD3200 TV
Wat is the code for sansui nexxtech universal remote
0463
Please rate our help ++++ thanks for using FIXYA
Sep 23, 2009 | Sansui DTV2760 27" TV
Sansui SAN1880 80g dvd recorder no colour
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Thanks
Rod
Mar 01, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Coloured Pixels in or around black areas when watching TV
This is know as a diffusion issue. Most times this can be corrected with some minor alignment on the pots on the YSUS pwb. Sometimes the YSUS pwb has failed and will need to be replaced.
Feb 03, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
TV Will not fire up.
try this,hang the collector pin of the HOT then try to switch on check the voltage its 115v dc,and check also the oscillation drive at the base of HOT take your VOM at 10v ac,ther must be a flactuate at the pointer.if the two procedure are good.plyback is deffective.but if u dont have any measured voltage at the collector of HOT ur problem is in the power supply. mc44608 is use at all old model philips tv.email me for wat happend
Dec 03, 2007 | SansuiM1315 TV
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
