Question about Mitsubishi WD-60738 TV
I have a Mitsubishi WD-60738 - about 3 or 4 years old. On Sunday heard a electronic 'popping' noise and TV turned off. When I turn it back on, i get audio, but no video - screen stays dark. Did my
Where can I get a new lamp to replace it?
    New Friend:
  • 3 Answers
Need new lamp.
Posted on Dec 21, 2015
    Top Expert:
  • Mitsubishi Master
  • 75,178 Answers
Check and replace the damaged component/s at its main power supply regulator section circuit. The sound you heard might be due to a busted capacitor. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 24, 2014
  • 1153 Answers
SOURCE: Dark screen since new
Wow only 10 then major work, hum. First if pic is:Split screen picture with one half darker than the other half. "Deep Field Imager" is set to the demo mode, press the "video" button repeatedly to cycle through the video settings until Deep Field Imager is accessed and then change the setting from demo to "on" or "off" depending on preference. Also u can try:1. Dark blue raster with faint movement in the background, suspect the FMT PCB part # 934C153001 . Also1. May be intermittent. Remove and reseat the DVI cable between the Chassis and Optical engine 2. Removing and reseating the DVI cable does not resolve, replace the Optical Engine part # 938P015020 Hope this helps Tom!!
Posted on Aug 22, 2007
SOURCE: Mitsubishi WD 52528 tv
I had the same problem last year - it was, indeed the bulb. At the time the tv was still under warranty and Mitsubishi sent me a replacement bulb.
Posted on Sep 11, 2008
tvtek
  • 1284 Answers
SOURCE: my wd-62530 model tv lihgt lamp comes on.the bulb
According to page 81 of your owners manual you are to contact Mitsubishi in the event the red light is on. Here is the paragraph from the booklet.
Service is required. Contact your dealer or a Mitsubishi Authorized
Service Center to arrange for a service evaluation. Listings
of Mitsubishi Authorized Service locations can be obtained from
our web site, www.mitsubishi-tv.com or by calling 1-800-332-2119.
Posted on Nov 25, 2009
  • 8457 Answers
SOURCE: My mitsubishi Model # WD-60737.
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Posted on Jan 11, 2011
  • 207 Answers
SOURCE: I have a Mitsubishi DLP
It's not the bulb. Google Mitsubishi WD-73737 blink codes. The blinking light is a self diagnostic tool and each blink code represents a certain problem.
Posted on Feb 20, 2011
I have a mitsubishi dlp tv model wd 60738 and when i turn it on the power button blinks for a second and then it stops but no picture and after while turns off
Most likely you need to replace the projection bulb. You can find them online. DLP sets are famous - or infamous - for burning out the bulbs/lamps.
Feb 05, 2018 | Mitsubishi Televison & Video
Mitsubishi WD-82837 pop noise and no power
Sounds like your bulb blew. Here is a link to a very good priced replacement bulb with housing . These are very simple to change yourself. http://www.projectorlampsworld.com/projector-manual/mitsubishi-wd-82837.html
also, here is a link to a video showing how easy it is. They are made to be replaced by the consumer.
How to replace the lamp in your Mitsubishi TV: http://youtu.be/_ONPuB5L-x4
Note, your bulb assembly may vary slightly from the one in the video, but it should come out and go in the same way.
You will need a plastic grocery bag or small garbage bag, some rubber, or latex, or clean cloth gloves, and a medium phillips screwdriver.
May 04, 2014 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Tv turns on with sound, black screen and then turns off
Most likely failing capacitor see this thread, http://www.fixya.com/search/p153336-mitsubishi_wd_62525_62_in_rear/common_capacitor_fail_tv Maybe a electronics reapir person...
Apr 08, 2014 | Mitsubishi WD-62825 62" Rear Projection...
I just got a new blub for my mitsubishi wd-60738 it plays ok for about 5 min then the screen flickers and i hear a whinning noise then it shut and a red light comes on in the front for about 10 sec then a...
Color wheel should be checked. Might need replacement. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 26, 2013 | Mitsubishi WD-60738 TV
Mitsubishi wd-60738 overheating
Look in the back for the fan area and see if you can feel/see it running. May be blocked or need to be replaced
Sep 16, 2012 | Mitsubishi WD-60738 TV
The screen turns off after a clicking noise after replacing the lamp
First is what was set doing before lamp was replaced?
Also it is very easy on the Mitsubishi sets to get the lamp in wrong where the two pins on the back either do not engage in the socket or even bend the socket out of the way---remove lamp and take a good look.
Another issue with these sets is dirt.
I will provide here a link for one question I answered here (there are several but one is enough) that had this same issue.
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
SD TECH
May 22, 2012 | Mitsubishi WD-60738 TV
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
My Mitsubishi WD-52631 went "POP"
No,probally a capacitor the help the power supply board to work or other boards to work is blown.Call some tv shops get a best quotes prices,get a tv tech out to it fix,if ur tv is out of warrenty.
Jun 17, 2010 | Mitsubishi WD-52631 52" Projection HDTV
HEARD LOUD POP NOISE DLP TV DOES NOT WORK
Following up on my Feb 7 post. My new lamp arrived, and I replaced it and it works great. The old lamp had many shards of glass come out of it. It was tore up. I saved some money buy purchasing just the lamp and not the cartridge. It's a little bit more work to take apart, but saves money. Mitsubishi wanted $289 for the lamp replacement kit. I got a lamp for $114. TV is working just fine now!
Jan 30, 2009 | Mitsubishi WD-57734 57" HDTV
Mitsubishi WD-60738 TV Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
