Question about Sansui Televison & Video
Picture not coming
Hi' when i switcht on tv there is some broken sound then picture not showing
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
Tv screen has gone black but still have sound when you shut the tv off and turn it back on the screen comes up but it flashes and goes black again
Hi Bob, The link below is a YouTube video showing how to fix a RCA television(DIFFERENT MODEL) NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
RCA 46LA45RQ tv repair No picture no power troubleshooting
May 01, 2016 | RCA L46WD250 46 in. LCD HDTV
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
My Coby 32'' LCD TV comes on but no picture.
Hi Chris,
Sounds like a popped capacitor......if you look inside again, try looking to see if any of the Capacitors are blown...
Jan 29, 2013 | Televison & Video
Hi there i am trying to connect a samsung lcd monitor to my pc via HDMI. i have the connection showing picture on my tv, however where i connect a 3.5mm jack from pc to tv no sound comes out. i have...
The connection to your tv is video only. You should hear sound coming from computer speakers. Unplug them and hook your stereo to that plug in.
Oct 04, 2009 | Computers & Internet
The tv reflects that it is showing in 480i whent he cable is at 1080i. i am using a hdmi cable, i know the tv is plug and play, but if that is not working can i manually switcht the tv to 1080.
There are several solution you can try. Go to your menu and manually set the TV to your own personal setting is the easiest step. The other is to change the source that generate the 1080 res. The HDTV is only capable of producing the signal it receives, not the other way around. If you have a reliable and true 1080 source, then your tuner is having some other issue or the HDMI port is bad. Try using the 5 component YCB plus sound to duplicate the problem. The Component port is capable of producing up to 1080i source. Let me know how this turn out.
Oct 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Nov 03, 2008 | Televison & Video
My rca
Tac switch defective. (front panel control switcht) replaced it.
Aug 04, 2008 | RCA F27442 27" TV
Broken TV :o(
hi
inside the tv can you notice the filament of the CRT is boosting or not
if it not boost check the fillament power supply in the board.then check the EHT (fly back transformer).
Mar 19, 2008 | Televison & Video
Sound and no picture
Hi, if your getting half a picture AND the other half is black the vertical circuit is failing, either solder is broken or vertical IC needs to be replaced, not a pricey fix, BMW Rider
Jan 04, 2008 | Sony KV-32S26 32" TV
Televison & Video Logo
22 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
