Question about Karcher 2500 PSI Pressure Washer
Water surges intermittently
Have gcv160 and water output surges at all speeds
Why does the honda engine surge
I have two pressure washers and honda engines on both. Carb needs to be cleaned I would bet,had to on both of mine. Good luck.
Jul 15, 2014 | Troy-Bilt 12avb29q711 Tb260 21-inch 160cc...
Car hesitates / surges at 45 to 55 mph, intermittently.
There was a problem with dirty or clogged fuel injectors in 2006. This was significant enough for Toyota to issue a Factory Service Bulletin (FSB) and later revise it.
Jan 14, 2014 | 2000 Toyota Camry Solara
P0720 stratus codes
code p0720 refers to output shaft speed sensor(OSS)--circuit malfunction====causes--wiring--OSS sensor--ECM/TCM
of it has just happened check the wiring and connections to the transmission for water and corrosion or replace the OSS sensor in the transmission.
May 08, 2013 | 2002 Jeep Liberty
I need help asap 2003 Expedition code p0171 and code p0712 i have and idea of the 1st code but whats the secound code i really need help i dont want to take it to a shop where there going to charge me alot...
P0700 Transmission Control System
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System -Electrical
P0703 Torque Converter/Brake Switch B Circuit
P0704 Clutch Pedal Position Switch -Circuit Malfunction
P0705 Transmission Range Sensor/Switch Circuit Malfunction (PRNDL Input)
P0706 Transmission Range Sensor/Switch Circuit Range/Performance
P0707 Transmission Range Sensor/Switch Circuit Low Input
P0708 Transmission Range Sensor/Switch Circuit High Input
P0709 Transmission Range Sensor/Switch Circuit intermittent
P0710 Transmission Fluid Temperature Sensor Circuit
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit
P0716 input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Shaft Speed Sensor Circuit
P0721 Output Shaft Speed Sensor Circuit Range/Performance
P0722 Output Shaft Speed Sensor Circuit No Signal
P0723 Output Shaft Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine RPM Input Circuit
P0726 Engine RPM Input Circuit Range/Performance
P0727 Engine RPM Input Circuit No Signal
P0728 Engine RPM Input Circuit Intermittent
P0729 Gear 6 Incorrect Ratio
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circuit
P0738 TCM Engine Speed Output Circuit Low
P0739 TCM Engine Speed Output Circuit High
P0740 Torque Converter Clutch Solenoid Circuit
P0741 Torque Converter Clutch Solenoid Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Solenoid Circuit Stuck On
P0743 Torque Converter Clutch Solenoid Circuit Electrical
Now i dont know a lot about automatics especially modern ones with all this fancy electronics thats used nowdays but i think its a fault with the temperature sensor for the gearbox.But where its located and what it looks like i have no idea it could even be mounted inside the gearbox .Sorry not a very good answer from a mechanic but?? very few of our europeon cars come with auto transmission .Evan when i do know whats wrong i cannot buy the parts for the gearbox as only re-con boxes supplied by the dealer so best advice is to try a specialist in auto box repairs only .PS some of my best students when i used to teach mechanics many moons ago were the girls so no excuses like iam only a girl please
Apr 22, 2013 | Cars & Trucks
RPM surges intermittently from 1000 to 2000 at idle or slow speed
ok a couple of things to try one is loosen the throttle cable so it has a little play in it and then you can check for vacume leaks using carb cleaner if rpms change you have a leak
Aug 17, 2009 | 1994 Honda Accord
Racing of a Honda 160 CC lawn mower engine
When a small engine "surges" in all speed ranges the possible causes are:
*Dirty air filter
*Water or contamination in the fuel system.
*Breaks in the spark plug wire (leaking), loose or corroded terminal connections causing an intermittent failure.
*Misadjusted or malfunctioning governor.
Problems with surging only when under load or at idle are likely caused by carb blockage or misadjustment.
Hope this helped and good luck to ya!
Jul 20, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Honda GCV160 5.5 on a pressure washer runs only intermittently
The problem is the plastic float in the carburetor, it's not adjustable and after sitting up with gas in it it distorts. Save yourself the trouble and buy a new one, you can get them online for $15-$20.
Mar 17, 2009 | Campbell Hausfeld Garden
When motor is at idle speed it surges
Try a simple test. It is ok to run the pump without water for a short time. Check idle speed without water in system to see if enginet surges. If it does not surge, then most likely the unloader/ pressure valve is causing the engine to surge when in the unloaded state. Life of unloader /pressure valve is shortened by letting system bypass for long periods of time. Enjoy
Nov 22, 2008 | Garden
Karcher 2500 PSI Pressure Washer Logo
200 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
