Question about Dynaudio BM5A Active Monitor
Bm5a blows fuse when turned on
I've changed the fuse several times and it keeps blowing when i turn it on.
    Sergeant:
  • 336 Answers
Blowing a fuse means that it has a dead short. The fuse does its job by protecting the other components while the circuit fails. Something is definitely burned out inside.
Posted on Mar 29, 2014
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 64 Answers
If the fuse blow it can be the diode bridge or one of the many capasitors in power supply. It can also be one of the amplifier IC's that has a short. There is one IC for bass and one for tweeter.
Posted on Sep 12, 2015
Why does my fuse blow out when i turn the amp on?
sounds like you have a dead short internally and unless you find and fix it will continue to blow fuses .
Aug 02, 2015 | SWR La15 Bass Combo Amplifier
Mackie profx12 fuse keep blow
Be sure the capacitor was replaced with the correct polarity?
in the beginning of my tech career I have replaced caps back words on accident. ..
Mar 06, 2015 | Mackie ProFX12 Professional Compact Mixer
Hammond organ c2 hook to a 147 leslie speaker it keep blow the 1.5 slo blo fuse how do I fix this
Like all the past answers, make sure everything is clean and lubricated expecially on the Lesley if it's a motorized rotating speaker, the slow blow fuse is telling you there is a problem ?
Feb 22, 2015 | Music
One side of my peavey xr86000 power mixer blew a fusework
Any unit that blows fuses needs to be serviced. Do not keep putting in fuses only for them to be blown again. Each time you put in a fuse and it blows, it will create more damage to the amplifier.
Jan 14, 2013 | Peavey XR 8600D Class D Powered Mixer
I have an Ibanez TSA15H amp that keeps blowing the F6 fuse. the fuse is a 500mA, but Ibanez told me to change it to a 100mA fuse and that would solve the problem. i did this, and it still blows. also...
This appears to be a common problem with this amp. Putting a smaller fuse will only cause it to blow easier...not sure what Ibanez techs were thinking. Mine blows with 500mA fuse...usually because failing to let it warm up the 30 seconds with standby switch off. I have used .75A-250V fuse and it eliminates the problem. Note: it also defeats the purpose of the fuse and leaves the circuit unprotected....voids warranty/fire risk/ shock risk/world will end, etc. I don't recommend using higher rated fuses but it appears that portion of the circuit draws more than the 1/2 amp fuse can handle.
Jun 29, 2011 | Ibanez Tube Screamer Series TSA15H Head...
My monitor is styill for working but the tweeter dont make any sound. i think its blowed up, is there a fuse a something that could be replaced in the amp?
no fuse in there unfortunately.
The problem could either be a blown tweeter (but that would likely cause distortion rather than silence) or a fault with the amp or crossover. Often it seems a relay is at fault in these instances with dynaudio monitors. In any case, unless you have considerable electronics knowledge (which I think it's fair to assume you don't ?) you won't be able to fix em yourself. Give dynaudio an email or call - they're helpful.
Dynaudio North America
1140 Tower Lane
Bensenville, Illinois 60106
USA
Phone (630) 238-4200
Fax (630) 238-0112
For Service: service@dynaudiousa.com
Apr 25, 2011 | Dynaudio BM5A MKII Monitor Studio Active
Blown fuse
Continued replacement of fuses without fixing the reason for them blowing MAY be doing additional damage to components in the unit.
It needs to go to a repair shop. It is likely there is damage in the power supply section or that of the power amplifier section.
Feb 28, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Mackie CR 1604 - Fuse keeps blowing
This is a rare occurrance for these units. It means that either one or more of the rectifier diodes has shorted or that one of the voltage regulators is bad. In any case, this is not a unit I would suggest a novice attempt to repair. Can you update this with your location so I can suggest a repair center? The actual repair should be straightforward and not too expensive. Thanks, Dan
Jun 09, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Dynaudio BM5A Active Monitor Logo
184 people viewed this question
Top Dynaudio Music Experts
Vito Vacirca Jr.
Are you a Dynaudio Music Expert? Answer questions, earn points and help others
