Question about Garden
Sovereign 40 mower power drtive Rear wheel comes off.
    Master:
  • 550 Answers
You've gotta laugh at this = put it back on .
Posted on Apr 09, 2014
SOURCE: Wheels do not freely roll backwards
SOUNDS LIKE THE PINONS ARE ON BACKWARDS. THE KEY SHOULD SLIDE OFF THE PINIONS WHEN PULLED BACK AND LOCK WHEN ENGAGED. YOU HAVE THE OPPOSITE PROBLEM OR ITS BACKWARDS!
Posted on Oct 16, 2008
  • 59 Answers
SOURCE: Have honda harmony 11 HR 216 that stopped being
it has a belt look under the mower
Posted on Jun 26, 2009
SOURCE: The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Posted on Jul 01, 2010
SOURCE: Broken rear axle on my Honda hydrostatic drive push mower
The last time I had a Honda mower in my repair shop I noticed that Honda doesnt do individual parts on its transmissions for mowers OR tillers.
You can fix this mower...but the transaxles are a bit expensive. Honda mowers do tend to be worth it though.
If the axle broke cleanly maybe someone would weld it back together?
I mean, the wheels dont turn that fast that balance would be an issue right? And I am sure the axle metal is cold rolled steel....which is to say it isnt thin cast material that would resist welding. If you take the transmission out of your mower and just take the parts to a good jobber maybe they would give it a try for 10-20 bucks? Dont expect a guarantee...but, for 20 bucks most shops wont even pick up a mower let alone try to fix it.
If this gives you another couple of years of service that would give you time to consider a replacement mower when the unit needs service again.
Posted on Jul 02, 2010
  • 6468 Answers
SOURCE: Drive wheels won't freewheel when pulling mower backwards,
pull off what looks like hub caps and check the wheel clutches
Posted on Apr 05, 2012
My YTH2648TDRF has only one rear wheel that engages the mower, shouldn't both rear wheels drive?
The rear drive uses a differential to drive the rear wheels, just like a car, the differential drives the wheel with least resistance, to enable the wheels to revolve at different speeds when going round corners; so it's quite normal for only one wheel to be driven. If your mower is having difficulty with slopes (do you call them grades?) I suggest you fit a new drive belt, a slipping belt is the most common cause of low power. Hope this helps.
Jan 12, 2016 | Husqvarna Garden
How do i remove the rear wheel on a Scott's s2046 riding mower?
you will probably have to heat it up with a torch to get it off take a dead blow hammer and hit the back side of tire go al arond it also use wd 40 spray on it keep using torch to heat up and beating the tire it will eventully come off
Sep 12, 2014 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Honda hrr2163tda rear drive problems
remove the rear whheels and check the drive lugs on the axles to see if broken or just rusted or stuck down
Feb 21, 2013 | Garden
How to remove rear drive wheels on old MTD 21
Daren Ingold's suggestion works only for the right rear wheel on my 19+ year old MTD Yardman 21" self propelled mower. The ratchet spur on rear left wheel is held on by a bolt in the center of the axle and a spline. Remove the center bolt and washer. Pry the ratchet spur off the spline by using three medium blade screwdrivers wedged between the wheel and the spur gently tapping the three screwdrivers in succession until the spur is half off the spline. It will come off easily after that. Remove the spur, noting direction, and remove the wheel and replace it with one of the front wheels (they're all the same design) if it is in better condition and use the rear wheel for the front. Good luck ever finding a new replacement for this particular wheel. My mower is 19+ years old but runs perfectly otherwise. Stored in dry basement.
Sep 23, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Craftsman lawn mower model 917,376673
you could put some screws threw the wheel into the tire or glue them on with plastic epoxy put there must be a defect in the batch of wheels there getting
Aug 08, 2012 | Craftsman 22" Rear Bag Rear Propelled High...
How to get rear wheel off
if it doesn't come off due to rust holding the wheel to the shaft and your trying to change the tire just change the tire with the wheel on the mower it's not as hard as it soulds
May 20, 2012 | Garden
I bought a Toro rear wheel drive lawnmower last May.I have never had any problems with it until now. the left rear wheel sticks. With the power off, I can roll it a little and it will stick and then I can...
The gear drive is probably just a little dirty. You can clean and lube the gears by pulling of the rear wheels and then remove the rear drive gears. Clean them and the axle and reinstall. Be careful to reinstall in the same direction as was removed. A smearing of axle grease in the axle and inside of the drive gears should take care of this.
Also remember that TORO mowers come with a 2 year warranty. Go to www.toro.com to find your nearest servicing dealer.
Nov 04, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 3 year old craftsman rear wheel propelled mower. when i bought it both rear wheels had power to them. Now only the right side has power, the left only rolls along. i have cleaned, adjusted and...
My thought is that there should be a key in the axle that has either come loose or has stripped out the slot on the wheel. Slowly take the wheels off and check out the findings.
Aug 15, 2010 | Craftsman Garden
Rear wheel drive does not push mower when engaged. But, when mower rear wheels are lifted off the ground, they turn weakly.
remove the rear wheels and check the gears in the wheels- they are plastic and part of the circumfrance on the inside of the wheel. If worn replace wheels.
also check belt- it should be tight with very little play when drive is engaged ( obvioulsy check this with engine off).
Nov 28, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
