Question about Fujifilm FinePix HS50EXR Digital Camera
My finepixHS50EXR start to recorder video and then just stops?
I start to take the video and it records for about 10 seconds then just stops. Im using a 16g memory card. Is it a setting problem?
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 78 Answers
The HS50EXR will only error stop recording in two scenarios, the SD card isn't fast enough to keep up with the camera, or the SD card capacity doesn't have enough space to continue.
The SD card should be a SDHC class 6 or higher card. Class 10 U1 or higher is best. Because the camera doesn't have a ram buffer, if the card it is recording to isn't fast enough to keep up, recording will stop. It is possible to purchase 16-128 Gb cards with no class rating and those should never be used.
Also the HS50EXR will only detect and determine card capacity based on function at the time of recording and not when the card is inserted. So after recording starts, it will test the card for capacity and speed and if neither are up to par, recording stops.
This may sound silly but in this same way it will read basically any card classed or unclassed as a media storage device and not a recording media. It's not until we need to use it will it run a quick test to see if it can continue. I know that is odd. It's as odd as find out this is their Cadillac model for the FinePix series but the tripod mount is PLASTIC!!! and the camera weigh over 650 gr!!!
Posted on Aug 30, 2015
    Sergeant:
  • 266 Answers
Sounds like it. Check with your manual.
Posted on Apr 20, 2014
Hi, I own a Nokia 5230. Before, I was able to record video smoothly and clearly without any kind of problem. Now, 90% of the time when I video, the video keeps going when recording, but the timer...
check if the phone memory is still at large and so on the memory card to,might so many files from your phone or card that's why the operation took some errors or buffer...
otherwise if this problem took on and so on,better reset your phone or restore it to it's factory default to refresh the memory of the phone and can do the operation smoothly...
if this solution helps....please rate me...thanks
Jun 03, 2011 | Cell Phones
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Will record for only few seconds then rewinds and stops recording
Could be a drum or heads. Looking at a $120 repair
Dec 31, 2008 | JVC GR-AX230 Camcorder
Broken video management file/ recording failure
Although the instructions don’t make it clear, it seems to be important that the camera is turned off before you connect or disconnect the USB cable. The instructions do mention that you should not delete or rename files on the camera except in the EXT_MOV folder. The camera’s firmware is apparently quite fragile about file names and the presence of the extra hidden folders that both the Windows and Macintosh operating systems create when you delete something.
Apr 07, 2008 | JVC Everio GZ-MG37 Camcorder
Dvd says it starts to record then just stops
have you tried to use dvd-rw? or try other movies to record with it.
Jan 22, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Problems recording VHS
hi bro i guss u have to buy new dvd not the rental one might have code on it for recording (copy right ) so u can't record
sorry
Dec 29, 2007 | JVC HR-S9600 S-VHS VCR
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Fujifilm FinePix HS50EXR Digital Camera Logo
60 people viewed this question
Top Fuji Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Fuji Health and Beauty Expert? Answer questions, earn points and help others
