Question about 2101L Keyless Entry System
Detailed wiring info????
Thanks to Larry I was able to determine that my 2002 Tacoma does have factory actuators but I'm still struggling trying to figure out how to connect the Avital 2101L keyless system to the factory wiring. The manual is vague (I think) on how to hook everything up and not damage the truck's computer. I've been searching the web for wiring details but I haven't found any info. Has anyone done this install on a 2002 Tacoma? Thanks.
  • Tom K
    Tom K Apr 26, 2014
    Thanks Devin
    Problem Solver:
  • 6 Answers
Hello Tom,
Power lock gray (- polarity) at white plug near fuse box.
Power unlock (- polarity) purple, at white plug near fuse box.
These wires will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door.
Posted on Apr 19, 2014
Keyless entry
If the doors are BOTH locking and unlocking by turning the key in the drivers door then there is already power actuators. The real question is are they factory or, aftermarket actuators. Is there a switch in the vehicle to operate the power door locks? If these are factory actuators then there is a gray(lock) and purple(unlock) wires at a white plug on the front of the fuse box, just below the fuses. You will need to test these wires while turning the key in the door. If these are aftermarket actuators you will see the wires in the boot coming in from the door, Blue and Green (standard) or, white and yellow (audiovox). Relays will be required to operate these wires (if no relay is present). It sounds like a relay is present already because you said that you can operate the passenger door lock from the drivers door.
Mar 12, 2014 | 2101L Keyless Entry System
How do i remove a I LOCK kill switch from a tacoma 2002
its a relay system tapped into the starter wire remove the sytem and connect the factory wires back together
Sep 21, 2012 | Toyota Tacoma Cars & Trucks
2002 toyota tacoma air damper doesn't seem to close all the way
Your blend door is actuated by the motor shown below. It is possible the door is sticking or the actuator has internal damage.
You would have to remove the heater to access the actuator...
Jul 08, 2017 | 2002 Toyota Tacoma
I recently purchased a 2002 toyota tacoma 3.4 V6 4X4. 98K on it. when idleing and driving it misses heavily, when you let off the gas its smooth. any suggestions? Thanks
I would start with a tune up, plugs, wires, cap, rotor, air flter, fuel filter. any of these that you have on your vehicle. Also check or have checked the fuel pressure.
Nov 16, 2010 | 2002 Toyota Tacoma
Colors of the IAT Sensor wires on a 2002 Toyota Tacoma 3.4 v6.
im adding a perfofmance chip to a 2002 tacoma v6 i need too find out what colors are the 2 iat wires.
Jun 06, 2010 | 2002 Toyota Tacoma
P/S pump installation
TTORA has complete factory manual links check it out http://www.tacomaterritory.com/forum/
Jul 21, 2009 | 2002 Toyota Tacoma
Need ignition firing order/ wiring diagram for 02 tacoma v6
Firing order: 1-2-3-4-5-6 Distributorless ignition system
Dec 01, 2008 | 2002 Toyota Tacoma
2002 Tacoma engages 4X4 at its liesure
Glad to provide you with my assistance.
It is my opinion that the shift motor/actuator inside the transfer case is compromised. I have observed this several times. The shift motor has contacts that actuate the front axle disconnect device, as well as engageing the 2-4WD modes. If all the wires are good, and all the connectors are clean, the remaining item will be replacemnt of the transfer case shift motor, this would be the solution.
Hope this help you, and thank you for choosing FixYa.
Oct 23, 2008 | 2002 Toyota Tacoma
2002 F250 Super Duty / A/C won't fnct
Ok,
first, in the passengers side, there is a module that controls the fan speed, NOT the dial button, its located inside the cab, as noted, passengers side, where the passenger rest his foot, it has two screws and a connector, and has a thermic protection that is probably faulty, you can get this for 30 bucks or so.
second, have you perform a refrigerant test?
if the system does not have sufficient refrigerant charge, the pressure switch would not activate the compressor clutchTry this and get back to me, if you tell me more detailed info, i will happily help you.
Good luck............
Jul 21, 2008 | 2002 Ford F250 Super Duty SuperCab
2101L Keyless Entry System Logo
219 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Colin Stickland
Colin Stickland
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
