How to configure tp link 300mbps ADSL2 + modem router (TD W8961ND) for Reliance broadband 2mbps(windows 7 laptop).i hav connected as DYNAMIC IP but every time the modem get turn off i hav to again run the set up through lan.which mode to use (pppoe ya DyNAMIC IP)?WHAT IS THE pvc and pvi value?when ever the router is on the laptops should detect the wifi automatic and connect.How to do this?
  • 3,320 Answers
Go into the router web interface and turn on DHCP. This will provide the IP address and routing information to your computer's network card,
Posted on Mar 25, 2014
How to set up my router with modem?
Connect the router to the modem with an ethernet cable, CAT 5, 6 or 7. Try amazon.
Jul 19, 2016 | TP-LINK Computers & Internet
I can't install
You need to read the manual here.
http://www.tp-link.com/Resources/document/TD-W8960N_V3_User_Guide.pdf
It needs power and the router plugging into the line via the line socket.
A Ethernet cable needs to plugged into one of the WAN ports to configure the router, the other end needed to be plugged into a pc.
Mar 14, 2015 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
How do i set up td-w8968
Configuring the PC
After you directly connect your PC to the modem router or connect your adapter to a Hub/Switch which has connected to the modem router, you need to configure your PC's IP address. Follow the steps below to configure it.
Step 1: Click the Start menu on your desktop, right click My Network Places, and then select Properties (shown in Figure 3-1).
2q==
Figure 3-1
Step 2: Right click Local Area Connection (LAN), and then select Properties.
swdfx3buhbuq8vtnw4buabext2fny6dn2yb3j8q11lqaa7caob5uowhnnroyklp8j49rogds1dhcra0pr2tkhnrwpxy9rwuva1si2takep29ra9ra4za1ud8vb3sawtr4nrnchs9zi6jyqads=Figure 3-2
Step 3: Select General tab, highlight Internet Protocol (TCP/IP), and then click the Properties button.
z
Figure 3-3
11
TD-W8968 300Mbps Wireless N USB ADSL2+ Modem Router User Guide Step 4: Configure the IP address as Figure 3-4 shows. After that, click OK.
2q==
Figure 3-4
IV' Note:
You can configure the PC to get an IP address automatically, select "Obtain an IP address automatically" and "Obtain DNS server address automatically" in the screen above.
Now, you can run the Ping command in the command prompt to verify the network connection. Please click the Start menu on your desktop, select run tab, type cmd or command in the field and press Enter. Type ping 192.168.1.1 on the next screen, and then press Enter.
If the result displayed is similar to the screen below, the connection between your PC and the modem router has been established.
z
Figure 3-5
12
i6omp5ex15+rw8zpt9gfv8vj5wpx8vvf6aaou6udwyj+bcbnckcjqlmkhemu0nmjjymslggvq3jjbwglgjydhcbxjwwpikyg9kfyzjqxllypyymxgeqznhtnzgqh5sydantn5+hwad6hmakstnizatkntp1cjsp1ktarvq1izat3k9aoapwddih1ltqzzs2hpjgaaow==w858adahab0rqghr0oahnqeixslaemvshei2orcdk0ypa9kimdshgn8rrjnr0oxunaga7kjv1gqiaow==If the result displayed is similar to the screen shown below, it means that your PC has not connected to the modem router.
2q==
Figure 3-6
You can check it following the steps below:
1) Is the connection between your PC and the modem router correct?
The LEDs of LAN port which you link to the device and the LEDs on your PC's adapter should be lit.
2) Is the TCP/IP configuration for your PC correct?
If the Router's IP address is 192.168.1.1, your PC's IP address must be within the range of 192.168.1.2 ~ 192.168.1.254.
3.2 Quick Installation Guide
With a Web-based utility, it is easy to configure and manage the TD-W8968 300Mbps Wireless N USB ADSL2+ Modem Router. The Web-based utility can be used on any Windows, Macintosh or UNIX OS with a Web browser, such as Microsoft Internet Explorer, Mozilla Firefox or Apple Safari.
1. To access the configuration utility, open a web-browser and type the default address http://192.168.1.1 in the address field of the browser.
z
Figure 3-7
After a moment, a login window will appear, similar to the Figure 3-8. Enter admin for the User Name and Password, both in lower case letters. Then click the OK button or press the Enter key.
mfvwnrkduldggaow==w858adahab0rqghr0oahnqeixslaemvshei2orcdk0ypa9kimdshgn8rrjnr0oxunaga7bgeabherbheibhezbhfebhfvbhfmbhf3bhgibhgzbhgqbhg7bhhmbhha7hgaaaow==
png;base64,r0lgodlhhwauahcamsh+glnvznr3yxjloibnawnyb3nvznqgt2zmawnlach5baeaaaaalamabqaqaaoahaaaaaaaaagdaaqidq0kcamaawgkdq0lcwaaawsgawadbaqdaamebasgcaoldqmdcaskcagdawmgcwsldqecawecawecawecawecawecawecawecawecawecawecawecawvaiaacwiceileyihmy6cggbbioc4wmzao0dpiu9yd4wixuiwjqszddhatgpalphmeeeptpbifwghancz9e8xkqaga7Figure 3-8
(V' Note:
  1. Do not mix up the user name and password with your ADSL account user name and password which are needed for PPP connections.
  2. If the above screen does not pop up, it means that your Web-browser has been set to a proxy. Go to Tools menu-Internet Options-Connections-LAN Settings, in the screen that appears, cancel the Using Proxy checkbox, and click OK to finish it.
Aug 19, 2014 | TP-Link Technologies TP-LINK TD-W8968 -...
Broadband disconnection problem
Unplug your router from the outlet then plug it back again to reset it.
Apr 16, 2012 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
We don't know how to connect the router
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 23, 2011 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Configuring DLink Wifi router for Reliance broadband
quick questions
1. how did you setup your modem?..is it via PPPoA or PPPoE
2. can you please provide the model number of your modem
thanks
Apr 24, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
