Question about Polaroid Tablets & eReaders
I can not shut down my computer at all
I'm not sure which HP Lap Top it is, I was installing Norton Security when a COMPLETE blue screen popped up & says IRQL_NOT_LESS_OR_EQUAL & an error code of STOP: 0x0000000A
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Polaroid Master
  • 901 Answers
Http://support.microsoft.com/kb/310918
Posted on Mar 25, 2014
How do i fix my hp tablet stream7 that has a black screan
You can try a factory reset, try holding the power button and the volume down key on the side of the tablet then use the up and down voulum keys to select factory reset and push the power button. That should bring up a screen that says are you sure? Use the volume keys to select yes and it should reset. If this doesnt work, you have to get ahold of hp customer service.
Jan 25, 2015 | HP Tablets & eReaders
Facebook comes on then goes out
This is usually a memory error. You may have too many apps open and need to close them.
Double click the home button to bring up all the open apps on your iPad. They will list in a line across the bottom of the screen. If you are on iOS7 or later you simply swipe the screen shot of the app upwards to close the app completely. Then go back to your home screen and open the app as you normally do. This should force the app to reboot and work as intended.
After closing all the apps you should then shut down the iPad completely. You can do this by holding the sleep button on the top edge for about 5 or more seconds. You will then see a slider on the touchscreen pop up that indicates you can shut down the device. After it is completely shut down, count to 10 and then press and hold the same sleep button on the top edge for 5 or more seconds to reboot the iPad. You can also plug it into your computer or charger at this point to force the iPad to turn on.
Sep 23, 2014 | Apple iPad Tablets & eReaders
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
IPad fail to print off a hp air printer
I had the same problem. When I went to the connected computer, used administrative privileges, went to the control panel, and repaired the Apple apps and iTunes. Restarted the iPad and it printed!
Feb 23, 2014 | Apple iPad Tablets & eReaders
How do you update
Before we begin you will need to have the following ready. ? The Coby Kyros with a battery level of 30% or more, the USB cable and an empty micro SD card with a minimum of 4G. The Micro SD card should be inserted into the Kyros. Start by going to our website www.cobyusa.com to download the zip file to your computer. The file can be found on the main page for the MID7015. It is titled "UPDATE.ZIP". It is important that you do not UNZIP the file.
Once file has been downloaded to your computer, turn the Kyros on and connect the unit to the computer via the included USB cable. At the top of the main page Go to the navigation bar and scroll down. A menu will open with several USB notifications.
Click on the External USB connection. This connection refers to the inserted SD card. A new menu will appear Click on MOUNT. Once complete your computer should recognize the Kyros device. A screen will open and show the Removable Storage drive. If this window does not open, please go to the start menu of your computer and select computer or my computer. There may be several drives shown. Please choose the one that corresponds to the SD card, it should show as empty. Open the drive. Now you may drag and drop the ZIP file into the removable storage drive. This process will take approximately 1 minute to complete.
When complete Go back to the Main Screen of the Coby Kyros Once again go to the top navigation bar and Turn off the USB Storage. Another window will appear with a turn off message. Make sure to click on this as well. Disconnect the Coby Kyros from the USB cord attached to the computer. Then Press the Power button, it will again prompt you to power off from the main screen twice.
Wait 5 seconds. During this time locate the power button and the return button. Press both buttons at the same time. Continue to hold the buttons down until you see the warning triangle and android logo. Once the symbols appear you may release.
Press the return button again. The reboot section will appear. You will use the Home and Menu keys to scroll through this section. The Home key scrolls up and the Menu key scrolls down.
Scroll down to Wipe data/factory reset. Press the return button to select. Scroll down to Yes and hit return. The Kyros will notate the Data wipe is complete.
Scroll down to Apply SDcard and press return The Kyros will notate Install from SD card complete. This will take approximately 1 minute .Select Reboot system now and hit return key
Congratulations you have just updated your Coby Kyros
For more info visit www.cobyusa.com
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 06, 2011 | Coby Kyros 716829701508 Tablet PC
I have an HP Pavilion tx 1220us bought 9/1/2007 and it is out of warranty and HP will not give me an extended warranty. Problem, when my laptop gets hot, it will eventually shut down, just like...
Try using a chillpad, it's just a little pad that has a fan on that you put in your lap and sit your laptop on that. When you put a laptop on something like carpet or a couch or your lap you block a lot of the ventilation which can cause it to overheat. When computers overheat they shutdown to prevent harming the circuitry.
Jul 25, 2011 | HP Pavilion tx1220us Tablet PC
Purchased lap top from work person I replaced added a password so I can not use it. HP Compaq tc 4400 how do I remove, the safest way thanks Harleygirl
Please let me know whats the OS you are using. If you are using XP it is a relatively simple reset procedure. However if you are using vista the easiest way to get rid of it would be to re-install the OS.
May 26, 2009 | Compaq tc4400 Tablet PC
Startup problem
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Dec 20, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Taskmanager popup
Let's start as simple as possible:
Do you have a loose connection / glitch at the power-connector? Check and solder (link to manual for disassembly is further down in this document)
To me this looks like a stuck key (not necessary one on the keyboard):
create live-usb-ubuntu:
1. download and burn ubuntu 8.10 to cd.
2. boot _any_ computer with it, connect >1GB USB stick.
3. System --> Administration --> Install to live usb
4. Boot from live-usb-stick that you just created
5. open terminal (Applications --> Accessories --> terminal)
6. paste this: sudo apt-get install xev
7. paste this: xev
8. hover with mouse over white box
9. make sure not to press any keys or move the mouse. Now flip the screen or try to recreate a situation in which the task manager would pop up in windows.
10. what's the output in the terminal window? Try to pinpoint exactly how and when the events are generated.
There should be no event generated, when you physically flip the display (which means you don't have to replace the hinge).
Press every single key you can find on the laptop. Verify that each key generates exactly one event.
If you find that there is a series of events generated without any key pressed, try to clean the malfunctioning key. (Service manual for disassembly)
It might possibly be a broken hinge (20USD). Flipping the display and pressing soft keys (Q, rotate, e) does not generate events in xev. Any other button does.
Sep 29, 2008 | Compaq tc4200 Tablet PC
Tablets & eReaders Logo
24 people viewed this question
Top Polaroid Tablets & eReaders Experts
John mullen
WTF Chuck.....
WTF Chuck.....
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
