Question about Intertherm Heating & Cooling
Intertherm propane furnace will not stay on
Gas will ignite as normal run for a minute or two then shut off gas and pilot light, then fan will come on. Have changed thermocouple, clean pilot assymbly, blew off heavy dust on fan switch sensors. Problem does not occure when I have access door open and watching flame only when the metal door is closed.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Your machine is missing the oxygen check your ventilation,
1. try to turn it for 1 minute with leaving the door open.
Posted on Mar 24, 2014
Testimonial: "turn what? So long as door is open it works sometimes with door close it works can not find a place to allow more air in chamber."
  • Russell Sadowski
    Russell Sadowski Mar 25, 2014
    Gas valve has an open ended copper tubing a little smaller than the thermocouple and runs from gas valve to pilot light assymbly what is this for?
  • 49 Answers
SOURCE: intertherm furnace explosive burner ignition
You absolutely must stay with Therin's recommendation. You do have a block or a cracked heat exchanger and this is nothing to toy with. Carbon Monoxide is very serious and dangerouos. All of your new furnaces should be power ventilated and you need to retire that one.
Posted on Nov 20, 2007
SOURCE: Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Posted on Jan 06, 2009
meBNme
  • 334 Answers
SOURCE: weak flame in intertherm furnace
Ok, so we can rule out the ignitor. (standing pilot systems can develop problems that will cause such symptoms.)
Check the gas pressure, make sure you are getting 11 to 14 PSI.
You need that after the regulator all the way to the manifold.
Also check for cracks in the heat exchanger, causing the wind from the blower to distort the flame pattern enough to cause improper contact with the flame sensor.
Make sure the burners and flame channels are clean of rust, and dibri build up, allowing the flame to properly contact the sensors.
Posted on Jan 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: pilot light wont stay lit.want to clean the orifice
You shut off the gas.
Shut off the power.
Remove the gas valve and burner assembly.
After cleaning and reassembly you must purge the system and use a gas leak detecting soap to verify no leaks before turning on the power.
Posted on Apr 15, 2009
  • 1015 Answers
SOURCE: gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Posted on Dec 21, 2009
Testimonial: "I did not expect such a quick response. These are hard times for us and we really appreciate your help. Thankyou for sharing your expertise."
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Intertherm gas furnace in mobile home..igniter comes on then nothing tries to fire byrners but nothing
by igniter I assume you mean the thermocoupler. are you turning the control button to run after you light the pilot light? Normally when those furnaces quit it is the thermocoupler that has quit. Get a new one and leave it in the furnace compartment as a spare.
Jan 06, 2015 | Intertherm Heating & Cooling
Furnace and pilot will not stay lit
The tube is gas supply for pilot. You have to make sure the thermocouple is in the flame at least half way and make sure its tight in the gas valve. There should be a small silver plug on the gas valve near the pilot supply tube. You can pop the cap and adjust the height of the pilot flame a little. Can you tell if it has a flame rod in or above the flame? If it does You can remove it and clean it with steel wool.
Mar 24, 2014 | Intertherm P3RA-060K Air Conditioner
You need combustion air to keep pilot and gas burning. You should have louvers or vents on that door. If you don't, you may have the blower door and combustion air doors switched. I have been on a couple services calls where the customer had reversed the doors without realizing it.
Dec 29, 2017 | Intertherm Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
William forshaire 435 runs well for awhile until
Try cleaning your thermocouple,and resetting it where was, which is located at the pilot flame. this should solve your problem.
Feb 23, 2010 | Heating & Cooling
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Jan 06, 2009 | Heating & Cooling
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
135 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
