Question about Whirlpool Duet 4.0 cu. ft. Front Load Washer - WFW9250WW
My whirlpool frontload washer does not have enough water to wash or rinse properly
My towels have become stiff and scratchy since I bought this machine. It is due to an inadequate amount of water in the machine. I have to set the machine to max rinse and then follow with an extra rinse cycle. I compared the level of water in my machine with another whirlpool frontloader and they are the same. How can I get my machine to fill with more water?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
1. do you have limescale in your source water, if yes you need to clean your machine with a special product that can be found in the market.
2. pressure sensor is broken
3. inlet filter is dirty you can unscrew the inlet pipe and look for a small filter and clean it.
Posted on Mar 24, 2014
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
What does error code f 51mean?
F51 error code is a motor rotor position sensor failure or a lower harness problem. You need to check the motor in manual test mode, not automatic test mode. This will check the hall sensors and do a spin test: Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds.
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. During the 5 second wait time with 88 showing in the display, press the same button once. You should be in manual test mode. If the button is not pressed within 5 seconds, the automatic test mode begins. The Rotor Position Sensor uses Wash, Rinse, and Spin indicators to detect the three hall sensors. Console can have up to two of these indicators on at the same time when the tub is not moving. Open the lid and rotate the basket by hand. The Wash, Rinse, and Spin indicators should toggle on and off according to the direction the tub is being turned.
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off.
http://www.applianceblog.com/mainforums/threads/32879-Whirlpool-Cabrio-UL-F51-Error-Codes
Jul 27, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
WHAT CAUSES WHIRLPOOL WASHER WET3300XQ NOT TO FILL UP?
I am in Ecuador and I have the same problem. 3 technicians have checked my unit and all of them have changed the water level switch without solving the problem. I am desperate. Please help :(
Jun 11, 2014 | Whirlpool WET3300XQ 27" Combination...
How do I fix my whirlpool cabrio washer is showing code sD
Ideally, you just run the washer without any detergent and it'll rinse out all the soap. Try that first. My Cabrio started doing that all the time, then stopped spinning out all the water. It had a host of problems and I opted to replace the washer. Hopefully the water rinse will fix the problem for you.
May 23, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
How do i take the front off of my whirpool duet washer to get to the filter?
the filter is in the bottom of washer. take off the lower panel there are three screws along the bottom I think they are 1/4 use a socket and you will see the filter in the front. it has a white door that you unscrew have some towel there to catch any water that runs out. you will be surprised what you might find in the filter anything from coins screws socks.....
Jan 20, 2014 | Whirlpool WFW9550WW Duet 27" 4.4 cu. ft....
Whirlpool Cabrio Washer fills but will not do anything else
1. Remove the drain hose from the drain and try to drain the water from the washer. To do this plug the washer back in and attempt another drain cycle. If water does not come out of the drain hose then you now know that the plumbing is in good working order. 2. Place the drain hose back into the drain and remove the washers cabinet.
3. You will now be able to see the pump and it should have two hoses attached to it.
4. Disconnect the hose coming from the basket. If water comes out you will know that nothing is clogging the basket.
5. If both of these tests come out good you now know that the problem is the pump.
6. Make sure you write down all relevant information such as the washing machine model and serial number.
7. Head to your local hardware store and buy a pump (they typically run about $15.00).
8. Remove the old pump and install the new one (make sure the washing machine is turned off and unplugged).
9. Test it. Let it run through a cycle to make sure everything is installed and working properly.
10. If it is still broken call a repairman or ask a handy friend to check it out for you.
Sep 20, 2012 | Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top...
Whirlpool Duet 4.0 cu. ft. Front Load Washer - WFW9250WW Logo
Top Whirlpool Water Heaters Experts
Donni Steen
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
