Question about Samsung LN-S2651D 26 in. LCD Television
My samsung LN-S2651D Comes on with perfect picture then after 5 minutes or so picture strarts to get white snow going down the screen
After tv warms up. The picture gets white snowy dots running down the screen and gets worse over time.
    Top Expert:
  • Samsung Master
  • 74,136 Answers
Tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 24, 2014
Testimonial: "I'm still checking out possible remedies. Fortunately I have an old Magnavox tube TV sill going strong. I'm going to test the tuner board and update progress or lack of soon. Thanks."
  • 257 Answers
SOURCE: Samsung LN-S3241D HDTV LCD snowy display
The main board may cause this problem. If it wass happened when you play DVD, so the main board needs replacing.
Posted on Aug 18, 2009
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
SOURCE: hi I have samsung plasma fpt5084 I have snowy
adjust vs and vsc voltages when tv is hot let tv fonction for a lease 3 hours if voltages do not fluctuate normally
replace y board
Posted on Apr 26, 2010
SOURCE: Samsung LCD TV slow to start
Dont have a solution, my samsung 46 inch is doing same thing. Have you found a solution?
Posted on Sep 04, 2010
diodeic
  • 1622 Answers
SOURCE: I have green "snow" through
Remove your HDMI cable from the Cable box, replace it with Component Cables. Do not use HDMI with Cable.
Normally if everything is green using component cables it would be because the Red/Blue cables are not fully inserted somewhere either on the display or on the source device. But since when you turn it on, with no source connected at all and it is green it sounds like it is a defective TV.
Sony builds the best TVs in the world and here is another fine example of there quality work. This is a firmware problem that the Sony engineers should know about. Contact Sony and inform them of this problem. Maybe they already have a firmware update for your TV, if not, then they need to start work on this issue.
I have been racking my brains trying to fix my boyfriend's new Samsung TV which gets the dreaded "green screen." Being a former PC Tech I knew there had to be a work around.The issue seems to be an incompatibiity with the receiver and cable box which sees it as a repeater.
Today I actually found it by accident fooling around with the cable tv box settings. BTW it is a Motorola Cable box.
This went all the way to the Engineer who had no solution as you all have experienced.
Here is what I did...
Turned off the Cable Box and pressed the menu setting on the motorola remote till a white screen popped up.
Scroll down and disable the overide settings turn to off
Then scroll down to additional hdmi settings and hit enter
Change it from hdmi to dvi
Then exit and turn your cable box back on
Your screen will flicker a bit and then focus back to normal
Now try changing your channels from sd to hd it should be fixed.
It fixed his today and I hoped it helped you...
Posted on Mar 31, 2011
Samsung LN-S2651D LCD TV no picture
What happens when you turn the TV on? Is there a clicking noise or popping sound?
May 28, 2014 | Samsung LN-T4665F 46 in. LCD Television
Picture comes on ok to my LN40C550 Samsung, then colored lines begin to appear through the middle of the screen, almost like a colored bar code
Sounds like a T'Con board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
Mar 25, 2014 | Samsung LN-S2651D 26 in. LCD Television
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
I have a line running thru my tv
vertical(up/down) or horizontal(left/right)? color/white? when you tap on the top of your tv does the line go back to a full screen? could be a makers defect.
Aug 22, 2011 | Samsung LN-S2651D 26 in. LCD Television
My plasma samsung model sp r4212 the screen goes black you can still hear and when picture comes back on there is also a buzzing sound
press the center power button for about 30 secs verify that the video cables are plugged in and try a different set of cables. If not unplug tv for 2 mins.
GOOD LUCK.
CNBY
Jun 03, 2010 | Samsung LN-S2651D 26 in. LCD Television
My Samsung LN-S2651D has sound but no picture
Check with Samsung, this model should still be under the 3 year warranty. You are having a problem with the backlight power supply. You can look on the back of the unit for the manuf. date, if its less than 3 years then go to www.samsung.com and process the online service request form.
I hope this helps,if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 20, 2010 | Samsung LN-S2651D 26 in. LCD Television
Aug 16, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung LN-S2651D 26 in. LCD Television Logo
154 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
