Question about Samsung Verizon Brightside Sch-u380 Black 3mp Qwerty Touch Phone
Samsung u380 microphone replacement
Microphone bad need to replace it
How to reset/delete unactivated U380 Lock Code for new use?
you just have to go to a mobile repair shop and ask that guy to install a fresh copy of the software that your mobile phone is required
Dec 09, 2015 | Samsung SCH-U380 Brightside Verizon Phone...
Touchscreen will not work on my Samsung Brightside SCH-U380
Other than a bad digitizer (touchscreen) or connection, sometimes just a tiny bit of gunk/debris gets in that tiny gap that goes around the outside of the screen. That often results in the same problem,, a non-working touchscreen. Take a very thin edged piece if cut plastic as a "tool" to clear out gunk/debris from this gap around the edge of the screen. Some people even have used like the opposite end of a sewing needle (not the pointed end).
Many ppl have fixed a non-working screen simply by cleaning out this tiny edge gunk. Give that a shot as a first step. If you use care, you won't damage anything.
Oct 28, 2014 | Samsung Verizon Brightside Sch-u380 Black...
Samsung flash
No. Verizon is CDMA. T-Mobile is GSM.
Aug 24, 2014 | Samsung SCH-U380 Brightside Verizon Phone...
People can't hear me durring calls. I can hear them.
Three possibilities: you have muted your microphone (sometimes by using an external mic it turns the internal one off), you have turned the mic down to the point where it's so low it isn't picking anything up, or the mic is broken.
Look around under settings and check the mic volume and mute settings. If they are okay then I'd say the mic has gone south.
Mar 06, 2014 | Samsung SCH-U380 Brightside Verizon Phone...
Samsung brightside will not turn on.
If the phone lights up when you plug in the charger it is probably the ribbon cable that flexes every time you open the keyboard. About 25 bucks from cellphonerepairshop.com. Be sure to flip up the little latches on the flex cable ends before attempting to plug or unplug the cable ends.
May 26, 2012 | Samsung Verizon Brightside Sch-u380 Black...
Samsung Verizon Brightside Sch-u380 Black 3mp Qwerty Touch Phone Logo
97 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
